1981 MCI 9 tag axle hub cap gasket part #
Started by RickB, March 06, 2010, 09:10:35 AM
RickB
Hey All
I have a leaky drivers side tag axle hub. I thought it was the plug so I replaced it but it's still leaking.
Gumpy sid they are a standard truck rear end and I have the MCI part # which is 15C-2-33 but I bet the parts guys at the local truck parts store are gonna want other info.
So, before I go driving to Brazil and back anybody have a more generic part # or another way of describing this?
Thanks in advance
Rick
JackConrad
Take the old one with you?  I think Stemco is the company that makes the ones used most often.  Jack
MC8Mike
My local NAPA store had the caps with gaskets when I needed them so I'm sure they could supply just the gasket. The part number for the cap was a cr1798 if that is any help.
1973 MC8 in progress. 8V92TA, HT740D, Ross Steering. Fallon, Nevada
DaveG
Stemco is the most popular mfg of hubcaps and gaskets. The C/R 1798 referenced should get you what you need. The Stemco hubcap gaskets are a 330-XXXX part number.
The cross reference I used (here at home) shows a Stemco 330-3060 gasket, 6 bolts, .375 hole size, 6" o.c....home this helps.
