Air Leak 1970 Eagle
Air Leak 1970 Eagle
Started by EagleRun, February 25, 2010, 09:44:35 AM
EagleRun
In the front there is an air leak.  Can you suggest where it would be, from the T's or a hole in line....  If I cut a hole in the back of the spare tire carrier will I be able to see or get to it.
Floyd
Have you checked the drain valve on the accessary tank?
It's hard to say, you need to go "Down Under" and locate the supspect.
Floyd,remove the bumper blade the one with the 4 bolts then remove the upper part of the bumper with the headlights only has 8- 3/8 bolts and you can see every line and valve in that area easy to do.
The 05 has two tanks in the front 1 between the front wheels the other is located in the door below the drivers window what Eagle calls the tool box check those for leaks .
The one in the side compartment below the electrical panel may have a cover hiding it
