Bus Freighter?
Bus Freighter?
Started by fr8bus, February 01, 2010, 09:51:25 PM
fr8bus
Is it possible?
I've come here to get the opinion of those who are familiar with bus conversions.
My situation is rather unique, and I wanted to explore the idea of a converted bus for temperature controlled freight for high valued plants that we ship all over the country. The weight of these items, and the racks they'd travel on is almost insignificant. My challenge is that relying on airfreight is not only costly but rather risky as airlines have exposed our plants to extreme temperatures on many occasions.
Why not use temperature controlled trucks?
I'm in the Northwest and many temperature controlled trucks transport nursery stock from here to all over the country on a daily basis. The problem is that they keep their trailers chilled to less than 50, and we need constant temperatures of no less than 65 and no more than 75.
I was thinking an old MCI102A3 or similar coach would make an ideal candidate for gutting the interior and installing a side bay door and ramp to rollon/off plant racks. Do this in temperature controlled warehouses, and the bus is just like a rolling greenhouse!
For those experienced with the conversion, what challenges do you see in this type of use? Is installing a cargo bay door on the side a realistic option? What type of mileage could I expect from running this type of configuration?
I've searched for more info on this topic, but I've yet to come across anyone using a coach for freight hauling. I'd love to hear of any examples (or attempts). Thanks.
HighTechRedneck
Wow, that is really stepping outside the box.   ;D
If you want to tackle the work, I don't see why it wouldn't be possible.  Perhaps look for a bus with wheelchair door/lift.  I think the biggest challenge would be maintaining the temperature accurately enough for your needs.  But that too probably can be done.
But I do feel like it is reinventing the wheel a bit.  You mentioned that others are running refrigerated trucks but are too cold.  It seems to me that if you are considering purchasing a bus for this and putting that much work into it, why not instead byy a refrigerated truck and adjust the thermostat controls to maintain the temperature you want?  Such a trailer would already be insulated and already have a refrigeration unit designed for maintaining a fairly steady temperature.
I love buses and bus conversion.  But I think in your case a truck would have several advantages:
  • As above, already made for the task.  Just alter the temperature.
  • Easier maintenance of the drive train and easier to find mechanics skilled with it.
  • If the tractor breaks down, you can detach and hire another one to complete the run.  On the other hand using a bus, suppose it broke down and getting parts took several days.
Either way will require commercial registration and a CDL to drive it.
I sell Freightliner trucks, and do love buses. But- I would highly recommend you get a 26,000lb gvw truck (here in California you do not need a CDL for 26,000lb and under).  The weight of a 24ft refer box and chassis would be about 15,000lbs-which would give you a freight carrying capacity of 9,000lbs.  Most any Thermoking or Carrier refer unit has both heat and cooling, so would be right for your application (I believe you can even get humidity control also).  You'd be look at about $65,000 for a higher powered chassis and about $25,000 for the refer box.  I know that's tickling $100k, but then you have a new vehicle with warranty AND with the most recent smog control devices (important on all commercial vehicles now). Good Luck, TomC
Nellie Wilson
I understand  Greyhound ran some buses in Calfornia that carried passengers and freight. If you could find one of those, it might come close to suiting your needs? And getting a factory modification sure beats cutting into the frame of a passenger bus.
A school bus with a wheel chair lift is another possibility. You can pick one up - in good shape - for under $3000. But not too practical if you're talking long haul. (Not as sexy, either :))
QuoteWhat type of mileage could I expect from running this type of configuration?
From what I've read, you might get around 7 mpg on the bus you describe (others on the board will have a better handle on this). I manage around 10 mpg, but I've got a smaller bus and a 4-speed... doubt they even make 'em anymore.
Aw, heck, just get the bus... join in the fun.
Nellie Wilson
Had to change a tire... >:(  got to put it on backward... :-\  still trying to fix it on photoshop... ??? ::) ???
PCC
Driving an aquarium (all the windows) becomes an issue when temperature limits (65 - 75F) are so tight.
I am working with an Air Conditioning engineer to find a way to keep my conversion within the same parameters, in all weather conditions (very hot or very cold), because of some electronics I will have on board.
So far, I have found some of the components I need to build a cooling system with 216,000 BTU of evaporator under my coach, and that is sufficient (they tell me).
I am still looking for the balance of the parts I need, but those engineers are just scratching their heads as to how to put it all together - they are the engineers, aren't they?
If you have a low clearance coach, you can put lots of rooftop A/C units up there with thermostatic controls, and be comfortable all day and night.
It would become a walk-through showroom, and smell nice too !!!
And yes, the loading ramp, like a wheelchair ramp, is very possible in many coaches.
NewbeeMC9
Get a transit with the wide doors and ramps already built in.  Then black out the windows, Factory AC may do the job for you. :)
oldmansax
I don't see why this would not be possible, even desirable.
I would buy as a bus as new as I could afford, leaving money in the budget for the conversion. Any good converter can remove the interior and skin the windows. You would add the side door & ramp at the same time. Use foamed in insulation (this is covered in other posts on this board) and build whatever rack you need to keep the plants.
If it were my project, I would leave a small "room" in the front for a bath & galley for the driver. Then the unit would be self contained and the driver would not be looking for truck stops or rest areas! A newer coach should have the factory A/C & heat in good condition so you can use that for temperature control. Most coaches have separate controls for driver & passengers. A couple of rooftops would add redundancy with a gen set to power them. Cruise Airs if you want to be fancy. You would still have all the bays for tanks, (would the plants need watering?) tools, genny, extra fuel tank (if wanted), and junk. Everybody has some junk!
One of the biggest pluses is the "cool" factor. Any good marketing exec could really use the bus for advertising to blow away the competition.
One word of caution, be sure to use a converter that believes in the concept. If not, they will use any excuse to excuse any problems with " I said in the beginning this wouldn't work right!"
Do you need a driver?   ..... or help?  :) :) :)
TOM
Post script: I know your problems with using  a regular refrigerated trailer for plants. I used to haul tropical plants out of Florida and bulbs out of Jersey many years ago. The refrigeration units are basic heat pumps. Maintaining 75F EVERYWHERE (even on the floor & around the doors) was almost impossible when traveling through 10F air.
1995 Wanderlodge WB40 current
1985 Wanderlodge PT36
1990 Holiday Rambler
1982 Wanderlodge PT40
1972 MCI MC7
fr8bus
Hi,
Thanks for all the great responses.
I'd love to just "get on the bus" and join you guys, but I'm still a ways away here. Right now I'm just exploring the concept. I can see this still being potentially viable and there are many pros/cons vs. a truck, aside from the freighter bus idea being pretty cool (or warm for that matter).
The product is tropical plants (orchids specifically) and everyone in the industry has trouble shipping them, especially to the nation's mid-section from either coast. The temperature controlled truck investment is another idea vs. the freight bus, but from what I can see, a typical reefer 26' box will not be sufficient in extreme climates (i.e. the high ceiling will be hot and the floor will be chilly when driving in extreme hot summer temps). Perhaps the latest technology can overcome this but a $100k investment is a pretty big hurdle, especially for one truck that can accommodate what I estimate to be about 500 plants.
A single unit freight bus could possibly have better climate controls using multiple (and redundant) systems. Humidity is yet another factor we'd like to control for.
It appears that circa 80's and even some early 90's transit coaches can be picked up for a fairly low price (less than $20k). Can I reasonably expect these to be able bodied machines that will hold up mechanically for 1,000-3,000 mile trips with relatively few stops? Please don't laugh if I'm way off here. We could conceivably tolerate some mechanical down time on the road if the climate systems remain in effect (i.e. it just simply becomes a greenhouse on broken down wheels). Since the conversion is rather minimalistic, what kind of additional costs roughly speaking, should I anticipate with a transit bus (tear out of current seating, installation of climate controls, retrofit for long-distance suitability)?
QuoteI understand  Greyhound ran some buses in Calfornia that carried passengers and freight.
That was what sorta got me started down this path. In fact, we currently do use Greyhound to ship cut flowers to the Oregon Coast. It's about a 4-6 hr. transit time (drop off to pick-up) and they hold up quite well in mild Oregon weather. We don't ship plants this way however.
Thanks for keeping this conversation going.
PCC
The reason we think you should seriously consider buses is because we are one with our freight (other people), and because our freight loads and unloads itself.
It also will afford you the ability to know your cargo is OK, because it is not a wall away (in the box behind the cab), but in the same room with you.
Providing separate climate systems (from the main engine) will protect your cargo from problems should the main engine 'break down', but these vehicles are designed not to break down, if properly maintained, because they must get their passengers home, so they are as reliable as any long haul vehicle can be.
A quality vehicle can be purchased within your stated budget, and there are a million people on this site who will step up to the plate, any time, to offer a hand or their advice as you move forward with this fantastic sounding project.
Transit buses will most likely require a gear ratio change if you want to go anything faster than 55mph.
Refer units on trucks have a separate engine to run them (good for break down on main engine).  I have a call into my Thermoking factory rep to see if they also have humidity controls on the refer units.  Good Luck, TomC
DaveG
Thanks to the Calif Air Resources Board, every reefer unit that comes into or through California now needs to meet new emission guidlines, basically the engine (engine family) needs to be less than 7 years old.
Tom has some accurate numbers on trucks and reefer bodies, selling/mounting/building/repairing bodies is what we do (not sell trucks). Just an FYI, I also think a truck is the way to go, and a non-compliant reefer will cost about $10,000 to upgrade with a new tier 4 (seven years) engine.
Good luck...nice thinking outside the box (or inside the bus!)
oldmansax
Fr8bus,
I still like the bus idea for all the reasons I and others have named. I don't think I would choose a transit bus for a platform because it will be easier to add a ramp & door to an intercity coach than to make a transit  into an intercity. Also, the intercity looks way cooler...... (sorry TomC)  IMHO!   ;D
Plants and flowers need about the same environment as humans & buses are uniquely designed to provide just that. Depending on how much you run into or thru the Communist State of California, the emissions issue may be moot. Also, I am not sure they would even check a bus for refrigeration emissions. If they mess with you very much, maybe you can just avoid them all together.
What can I say....
I LIKE A BUS!!!   ;D ;D
TOM
1972 MCI MC7
If this is intended to be a profit generating venture...
Truck chassis are cheaper/easier/faster to maintain than a coach chassis.
Installing a more sophisticated HVAC system in the box will give you the best of people transport environment and all the pluses of a truck chassis over a coach.
If using an old used coach for transporting stuff worked on the economic side, it would already be happening.
Those seeking profits are a creative bunch, but they are also astute in their ability to discard losing propositions.
NewbeeMC9
Quote from: TomC on February 02, 2010, 12:54:14 PM
............ Good Luck, TomC
Yes that could be an issue,  Isn't there some transits with Series 50 engines and  an electronic tranny with the 2 highest gears programed to be turned off and just need to be turned back on.  Some can be found at auctions.  Maybe somebody can clarify or nullify my muttering :D
The good thing about the transits is they are low and have the extra wide doors and ramps already, easy on the lifting :o.  The bad(not really) thing is they are low and require some thought to get stuff underneath like Black water tanks.
MC9 have bays designed to carry cargo., you could design the inside to do that too.  Lotsa options.
Maybe a bus like Oddessey, a Neoplan with the extra stair way and entrance way and bathroom downstairs.
Eagles frames are kinder to retrofitting slides etc.
Anyway Fr8bus welcome to the madness and let know what you figure out. :)
Nellie Wilson
Last word from me:
If you'd said 'orchids' in the first place, I could have been more helpful.
Get a really good bus (15,00- 20,000 grand), refresh the heating and A/C (DIY project) and deliver your orchids. And enjoy your life along the way.
How do I know? Raymond Burr (a/k/a 'Perry Mason' and 'Ironsides') retired to Suva (Fiji) to raise (you guessed it) orchids. And who delivered those orchids "stateside?" A very dear friend of mine.
He made zero stops (excepting Christmas Island, to fuel up) on his way to California. He could have dropped them in Hawaii (or even run over to Australia and dumped them on Quantas).
But Mr. Burr wouldn't have it... those plants got personal attention from port to dock. (And his gardeners did too... they got bacon & eggs every morning :))
And who picked up those plants in San Diego? I don't know the carrier, but I know they used buses.
Nellie Wilson
