This's a question that's been driving me bats for months......
Started by Ncbob, July 27, 2006, 05:01:09 PM
Ncbob
Every other day I need to air up my bus to keep the old broad 'on her feet' so to speak.  Whan I get to BK's soiree at the end of October I'l have the opportunity to put her over the Pit and do some extensive spraying with the detergent peppered water and find whatever minor leaks I have...but in the meantime...and my questions is:
How, and where if at all possible, does one block up an MC5A so that it doesn't settle out after prolonged periods of parking?  The previous owner had blocks to put under the jack points (Duh!) which probably made him feel better but I'm a realist and I've figured out that his way is an excercise in frustration.
If it can't be done without stressing the frame....I'll settle for that...but...inquiring minds want to know! ;)
Stan
A block between the body jack points and the ground will hold the bus level to the ground. A block beside an air bag will hold it level to the axle, the same as the airbag does.
NJT5047
Bob, may I ask why you want it to stay aired up?   You could hook up the shop air (with a water separator of course) and air up the bus to get it back up.   I have to let the air out of my coach to get it into the barn.  They air up really fast without the air suspension in the circuit.
Unless you can isolate the airbags from the general system, and your airbags are relatively new, it ain't likely to stay up long.  Mine won't.  That's why I installed ball valves between the airbags and leveling valves.  I don't use a front leveling valve.  Just a regulator and valves so that I can exhaust air when I want for leveling.
You can bet that every regulator on your bus is leaking, as is the AC belt tensioner cyl, blower belt tens cyl, wipers and wiper controls, drain valves on tanks, possible air suspension may have major leaks,  air compressor gov, filter dryer...the list is endless.
I agree, getting it on a pit will be invaluable.   Get you a jumper so you can attach shop air to your coach at BKs...makes dx air systems much easier.
See you at Timmonsville, JR
JR Lynch , Charlotte, NC
Ayn Rand
My bus will settle in about a week on its bumpers.  Doesn't hurt anything, and as a matter a fact I like it since it is then easier to get into the bus from the ground level.  I have manual height adjusting solenoids besides the automatic leveling valves. I know that the auto leveling valves are the culprit since when I have the manual valves activated, it'll stay up for two weeks (have new air bags also).  So don't get wigged out when the bus settles back down, the bags also settle down quite nicely.  It's when you don't have air in the air bags then lift the bus up that pinching of the bags can occur.  Good Luck, TomC
JackConrad
Bob,
   Are you getting in and out of the bus many times while it is sitting?  Once the air pressure bleeds off of the system, everytime you step into the bus, the ride height valve arm moves slightly to add air but since there is no air pressure in the line coming to the valve, a little air from the bag is lost. These small loses add up. Also ride height valves are known to be a common source of air leaks. As was mentiioned, if possible, conect your bus to shop air and see if this makes a difference.
   When we installed our leveling system, we put a solenoid between the air bags and the ride height valve that is closed except when bus is running. Bus will now stay up for weeks.  Hope this helps and lookin' forward to meetin' ya'll at
Timmonsville.  Jack
oldmansax
FIX THE LEAKS!!!!.......if you can! LOL. Leaks cost more than you think. Wear & tear on the compressor, the addition of moisture into the system, the extra fuel to manufacture the HP to turn the air compressor,  the list goes on.
That said, we all know it is about impossible to get 'em all. You may want to consider installing a small 12v compressor for when the bus is off. Switched & fused of course. Do away with the standard pressure switch and use a wide differential switch you can set to maybe 70 cut in & 120 cut off. Nick can probably sell you one. That way it won't be coming on very much.
my $0.06 worth (inflation + I'm expensive ;D)
1995 Wanderlodge WB40 current
1985 Wanderlodge PT36
1990 Holiday Rambler
1982 Wanderlodge PT40
1972 MCI MC7
FloridaCliff
Bob,
I woulld bet there are some stops by the air bags to make sure the that the bus doesn't settle all the way down on the
air bags.
There are on my GMC.
Just put some 4X4' pieces's in the gaps and let it settle down on these for a temp solution.
Cliff
Mark Twain
NC,
I have the same concern on my 4104. I've used the blocks between the rubber bumper and frame for short periods but this bumper is not designed for constant pressure and will flatten over time. It is desgned to keep the suspension and frame from hitting under extreme conditions.
I've been chasing air leaks for a year now. Every time I find one I think the problem is solved but it never is. I guess eventually I will find all the leaks but I have my doubts.
Cold weather makes the air leak out very fast as does parking it on uneven ground.
When I drive the bus on a long trip it will stay up for days but after it sits a couple of weeks it won't hold air more than a few hours?? Never have figured that one out.
FloridaCliff
Gusc,
I have made it a personal mission to find and stop my air leaks.
I finally after much diligence have my suspension under control, doesn't drop at all unless like Jack said
that I am going in and out alot, even then it is now minor.
The thing I found was that every time a leak was fixed, that we were upping the pressure in the system and exposing some other leaks that had
not shown up before or were unnoticable at the lower pressure in that area.
So, it ends up fix one, recheck everything again.  Tedious, but the joy of no air loss in my suspension now ;D only a BusNut could appreciate.
Thats sort of what happended with my DD3's, one side had a park diaphram leak, fixed it, took a long trip, now the other side didn't like all that new pressure.
Now that diaphram "gave up the ghost"
And last, everything you fix at home is a pleasure, compared to the side of the road(and believe me. I know) ::)
Keep up the good fight, you will get there. ;)
Cliff
Mark Twain
Quote from: FloridaCracker on July 28, 2006, 06:03:19 AM
Cliff
4 Foot pieces? Is this a monster bus??? Sorry I couldn't resist!!!  BK   ;D
DrivingMissLazy
That way you do not have to craw under the bus to locate them in place. LOL
Quote from: Busted Knuckle on July 29, 2006, 07:43:28 PM
Cliff
FloridaCliff
Mark Twain
Hartley
On your blocks, Insert a couple of screw eyebolts on two sides. attach a bit of nylon rope to one of the eyes
and make up a long J-hook with a handle on it out of 5/16 steel rod.
Use the Handle to pick up the blocks and insert or adjust them or even remove them. The cord is to retrieve the blocks
when you drop them or want to move them.
----------                  (_________________|
|        |D                                               |
Silly But it works and the J-Hook is good for reaching under the car, truck or bus to drag jacks and jack stands out of the
way too...
Barn Owl
Quote  When we installed our leveling system, we put a solenoid between the air bags and the ride height valve that is closed except when bus is running. Bus will now stay up for weeks.(Jack Conrad)
I believe this is what the previous owner did to my bus. Even when all air pressure is lost it still keeps its bags full. The longest I have gone without starting my bus is three weeks, and it still had not lost its bag air.
The next time I park the bus for any length of time I am going to tamp a stake into the ground beside it and attempt to measure any drop in height. I am not exaggerating, it will take weeks.
