ramco mirror question
Started by crown, November 26, 2009, 05:55:54 PM
crown
 i have a set of ramco elec. heated mirrors these are the ones that are split upper & lower
what i need to known is what kind of swith do i need and where to find one pics if you
have thanks
john
57 crown
costa rica
A little more info please are they remote also
crown
hi luvrbus dont known what you meen by remote  these mirrors are split in two upper mirror is flat and moterized will move in
all directions lower mirror is curved and is moterized also they have heat also there are 10 wires comming out the arm a friend
played with them and told me what wires do what but i dont known what type swith to use thanks
john
57 crown
costa rica
The easy way is to buy the switches from Ramco 219-294-7691 any toggle switch will work for the heat, the control for the mirrors heads are a 4 way selectable switch with a off/on for each mirror plus they will send you instructions
Lonnie time to go
IF i was to guess  "guess'
You need two position controllers for top and bottom like your car.
Another switch for the heat but on a timer or temp sensor like car rear window defrost.
You don't want to overheat the mirror.
This is if you had to build your own.
Just a idea
Lonnie
1976 4905
JohnEd
I want the problem that Crown has.  Anybody got power mirrors for sale?
scanzel
Ramco has a switch kit for the mirrors. Also check out Velvac mirrors on the Ebay site. Periodically they have some real good buys on the Velvacs. I won the bid on a set of heated, motorized upper/lower and turn signal on arm in black for $482 including shipping. These sell at Velvac for over $600 each. I lost out on a chrome set a while back, outbid by $10, I wasn't paying attention that day. Velvac switch kits are about $100 each, includes switches, wiring harness and instructions. Good Luck.
Steve Canzellarini
Myrtle Beach, SC
1989 Prevost XL
JackConrad
John,
    I have the wiring schematic somewhere, I will try to find it.  I ended up just buying 2 switches from Ramco (one each for drivers and passengers mirror).  Each switch has a 4 way toggle to adjust and a switch to change from upper to lower.  For the heaters, I used a standard SPST switch with a red LED indicator (one switch for both mirrors).  Jack
JohnEd, I have saw the mirrors sell for 200 bucks a set in Quartzsite with the arms if you are looking a set fwiw.
BG6
Quote from: crown on November 26, 2009, 05:55:54 PM
have thanks
Contact Ramco tech support.  I got several calls back while they tracked down the info I needed.on a couple of USED mirrors that I got when an RV repair place went hooves-up.  Ramco support is the best, and so are their products.
crown
 hi all first off would be kinda hard to call them from costa rica do they have a web page ? jack if you can find that
imfo that would help a lot any pictures of what the swiths look like thanks
john
57 crown
costa rica
