BIG battery how to check
Started by wrench, November 09, 2009, 05:07:09 PM
wrench
  I am looking at an electric fork lift 48 VDC. anyway to know how bad or good are the battery?  How do I do that?
     thanks      wrench
Hi Wrench,
You will need to use a Hydrometer. Check the spacific gravity of each cell to see if they are all equal.
If there are cells that don't float, then they are bad. Not much more you can do other then that!
It really dosen't matter if they are not floating all the way up but, rather they be equally at the same level.
Good Luck
DaveG
If you can find a big enough load tester, put a load on it! Just a joke...don't know that they make a load tester that big!
Slow Rider
You can load test each cell individually.  According to Dallas, each cell is also rebuildable/replaceable.  The final voltage is just in how you configure them.  It sure is a darn big box to fool with though.
Frank
The MCI has landed..... We are home.
Dale City Va.  Just a southern suburb of DC
Yes I am a BUSNUT
1976 MCI MC8
Just Dallas
Ed Hackenbruch
 Had to think about it for about 10 seconds before i realized what a DA driver was. ;D ;D ;D
wrench
    Thanks all, been very helpfull.
          wrench
