Shell spirax GSX transmission oil
Started by bevans6, November 07, 2009, 02:38:44 PM
I was checking the transmission oil in my Spicer 8844 and it looked red to me, which I always equate with auto trans fluid.  I had been meaning to change it to a SAE 50 oil to see if that help the "engage gear at a stop light" issue, and so I went down to my truck supply store to see what they had.  They only had pails of SAE 50 engine oil and I only need 2 gallons, so I picked up some of the Shell Spirax GSX synthetic SAE 50 transmission specific oil that they had.  Not cheap at $10 a litre, but it looks like just the thing, fully synthetic, the right grade, and designed for gearboxes.  I'll put it in and see how it does!  Interested to see if I can tell the difference shifting.
http://www.shellusserver.com/products/pdf/SpiraxGSX.pdf
Utahclaimjumper
If you going from ATF too 50# for this problem, your going in the wrong direction, you want the thinest viscosity you can use.>>>Dan
Utclmjmpr  (rufcmpn)
EX 4106 (presently SOB)
Cedar City, Ut.
72 VW Baja towed
