MCI-9 Engine cooling fan?
Started by mtamaaj, September 26, 2009, 07:00:57 AM
mtamaaj
Hello all,
After purchasing our first bus, a 1981 MC9, I made to home(a trip of about 4 hours), but it then developed a bad vibration.  I found that one of the squirrel cage fans came apart.  4 of the bades came off, after hitting the housing.  Has this ever happened to anyone else?  Does anyone know where to find a new or used one with out paying over $800 each?  Thanks.....
mccarlk
not sure id the ones i have   mci5a are the same , you can ave them , pay for the shipping, i changed mine over to hydraulic set up, does anybody know if these will help ?
treat every day like is your last, just make sure you dont spend all your money,in case its not!!!!!!!!!!!!!!
mtamaaj
Thanks mccarlk,
if they are the same that would be great.  Mine measure 12" X 12".
edvanland
Call Luke at US Coach 856-767-4848.
Very easy to work with and he is honest.
ED
Ed Van
MCI 7
Cornville, AZ
Mtamaaj -
Which engine do you have in your MC-9?
MCI used different squirrel cages depending on the powertrain, so you have to be careful to get replacements that are correctly sized.
Changing them out is a real bear - best to pull the entire assembly and swap the squirrels on the workbench, rather than six feet in the air.
While you're in there, it would also be a good time to get the radiators professionally cleaned, and once re-installed, sealed completely all around.  This will make sure that all the air being pulled in by the blowers goes thru, rather than around, the rads.
johns4104s
Mtamaaj
Call Sam Kaylor 785-878-3405,Kansas, He will know what you need and will ship it reasonable.
