Pex Floor heating pipe
Started by alltech, June 24, 2009, 05:57:21 AM
alltech
I am planning on using the 5/8 pex heating tubing to run to all my heaters in the coach. Has anyone done this and if so how did you connect up to the heaters?
I was thinking you might have to transition to heater hose first and then to the heater?
Regards,
Ross
1988 102C3 8V92
That is my plan right now unless I come up with something better.  This is how Brian Diehl did his too.
My friend works at a large custom refrigeration manufacturer and might be able to come up with parts to connect the PEX directly.  I fell a little safer without heater hose to leak down the road.
