Front wheel drive system for any vehicle
Started by TomC, April 06, 2009, 12:53:19 PM
I happened on this system that replaces your two front hubs with hubs that have 55hp motors on each side for a total of 110hp of pulling power provided by a hydraulic system.  Just add a hydraulic pump to either the pto output of your transmission or add a belt driven pump to the engine-run the hydraulic lines to the front axle, and your ready to go off road and not get stuck (Sean?).  Course, the system is around $35,000.00 installed.  Go to WWW.Tuthill.com and look for the EZ Trac system-interesting idea.  Good Luck, TomC
Gary '79 5C
Tom,
Maybe you can install on your MB 300D with oversized tires and start rock climbing in Ca. Alot classier than a Jeep CJ...
Nice butt a liitle pricey.
Have a Great Day
Gary
Ocean City, NJ
