Diesel Fuel
Diesel Fuel
Started by Beatenbo, June 28, 2006, 09:48:15 PM
Beatenbo
Got my FlyingJ magazine today. Had a big article about Ultra Low Sulfur Diesel. Be sure and get one. Interesting note. Changing their truck stops now.Somone told me they got less MPG with FlyingJ fuel. Their article spoke of less milage, less sulphur. Charlie
Moof
I guess I'm a bit chatty tonight.  I am on the Community Action Committee for our local Flint Hills Refinary.  We have been doing a lot of talking about the low sulphur fuel.  I haven't talked to any diesel experts but from what I have gathered from the refinary experts there may be a lubricity issue with diesels not built for this fuel.  If this is true I expect there are additives that will help.
I've already been running the Ultra Low Sulfur Diesel in my '84 Mercedes Turbodiesel, and truth be told, don't feel any difference in performance.  Maybe a bit less smoke, but still can smoke if I stab the throttle too much.  You'll notice now there is a decal on the Diesel pumps that indicates whether it is low sulfur Diesel (500ppm) or ultra low sulfur Diesel (15ppm).  Might be a few cents more, and I'll bet that hardly anyone is going to have anything happen to their injectors.  Good Luck, TomC
Frank @ TX
I think they are selling it here in PA already.
Is there a additive for it or not ?
I've heard a few folks say already that "there should be an additive for it when it gets sold" .
Does anyone know about one that will work with DD, or any other engine?   :o
Ncbob
I've been told...some years ago that ATF  Type "A" (cheap) is a good valve top oil for diesel...but I'm sure someone will have a better recommendation.
Bob
Kristinsgrandpa
I would hate to be using ATF and have my tank checked by the State/Feds looking for off-road fuel. They are the same color. Any tint at all might be enough to cause major deflation of the wallet.
Something to consider.
Ed.
H3Jim
During Katrina, it was legal to purchase red dye fuel and use it.  I was the gov't way of helping to ensure there would be no shortages.  I figure that's a free pass to get out of "red dye" hot water.  As few miles as we put on, its very conceivable that the red dye could stay in there for years.
Its only 20 cents a gallon cheaper these days, a much smaller % of the cost of fuel these  days, hardly worth the risk.
Jim Stewart
Quote from: H3Jim on June 29, 2006, 09:17:15 PM
Yes you are correct, but along with the dyed fuel the supplier had to give you a notice from the gubberment stating that the taxes had indeed been paid on that fuel! I know we were at Katrina & Rita relief for 38 days straight! I still have a copy of those statements on each bus just incase!  ;D BK
brojcol
Do any of you KNOW of an instance where a RV'er was fined for having red fuel in their tank?
"Ask yourself this question...Are you funky enough to be a globetrotter?  Well are you???  ARE YOU?!?!
deal with it."            Professor Bubblegum Tate
The red dye that is used for Diesel has a definite chemical makeup to it.  While you might be initially sited for the red color of the fuel, once it had been analyzed at the lab and found that it was auto trans fluid, you wouldn't be sited.  It is still a mess that requires you going to court and paying the fines.  In the end you'd get your fines back, but in my opinion, just not worth the few cents you save.
One point along these lines-it may be a real deal to buy a bus in the first place, but remember this is a heavy duty commercial vehicle that uses the most expensive, largest equipment available on the road.  Translated-buses cost alot to run and to repair.  If you don't have the spare funds to maintain them correctly, maybe should consider a bit smaller of a vehicle.  Buses are as close to a land yacht (and the costs that yachts incur for upkeep) in overall cost.  The only difference, you pour money into the sea with a yacht, with a bus you just pour the money down a sink hole.  But-I'm a nut, and it is my hobby.  Good Luck, TomC
Frank @ TX
Quote from: Frank @ PA on June 29, 2006, 11:59:51 AM
So. the answer seems to be NO, other than ATF no one knows of a lube that can be put in the tank to help with the dry fuel.
Since we carry a bit of engine oil replacement with us , would it hurt any thing to use some 40wt in the tank at fillup time ?
How much would be the right amount per 100 gal ??
boogiethecat
1962 Crown
San Diego, Ca
Beatenbo
I am concerned about my 2 stroker being lubed right, but I have been fooling with buses since I was a teenagerl ( a ong long time) and I am on my tenth bus. I have driven over a million miles in the music business and I can't remember but one time in over 40 years in a private coach being question about any thing much less any kind of fuel check. I had a GA trooper give me some flack about 20 years ago about a car tag on a bus. The only problem over the years has been a few speed limit discussions. I can't imagine a can of ATF causing a problem. Happy busing, Charlie  ;D
Ncbob
My thoughts on a qt. of ATF in a 140 tank are that it's going to be soooo diluted that anyone sticking tanks wouldn't care.
The DOT, State Inspectors, or whatever are more interested in nailing the OTR trucker who're trying to beat the system.  These guys have to buy fuel stickers for the States they run in and use one helluva lot more fuel in a month than we could use in a year. IMO, if they want to test my tanks for off-road fuel I believe I'd tell them...they've got too much free time on their hands!
FWIW
NCbob
NewbeeMC9
They have been rumored to check tanks at a rodeo or cattle auction or such since farmers are likely to use off road and be tempted to use it, plus theres a collection of tanks to check.
