Electric heat in floor
Started by Tom Y, January 26, 2009, 09:43:58 AM
Tom Y
Have any of you tried this in your bus?  http://www.nuheat.com/products/overview.html  Someone suggested I try it. Not sure how to make this open as a link.  Thanks Tom Y
Tom Yaegle
VanTare
I have it and like it this is my 3rd with it but it will kill a battery bank in a short period of time has a big amp draw regardless of what they tell you and is not cheap to repair or to buy
David
Sojourner
Tom Y
Thanks but I am to far gone or along to go with water heat. Some one suggested this under the carpet.  Thanks Tom
Tom Yaegle
VanTare
Tom Nuheat is not manufactured to use under carpet never seen anybody try that
David
Lin
Well, I hope their product is better than their website.  I am assuming that they are selling mats with built in electric heat.  There is no reason that it will not work as well as any other electric heat when you have power.  I'm sure that you have been through a bunch of different options, but I find the small, quite, plastic electric heaters to be quite nice.  Of course, if you are without a shore connection, any electric heat will need you genset to be pumping.  The Webasto Air Top type diesel heaters offer one, although not cheap option.  We have gone with propane.  We have one furnace, but also have the RV catalytic type.  I did not permanently install it, but put it on a quick disconnect instead.  I suppose you have already looked at what Dickinson's has to offer (http://www.dickinsonmarine.com/index.html).  Although I conceptually like the products, they do not seem to fit us very well.  We are only 35 feet long, so blocking off space can be an issue.
TomCat
I have NuHeat mats under my kitchen and bathroom Italian tile floors, and seeing as it's 5* outside right now, I wouldn't trade them for a sack of gold lugnuts!
Jay
87 SaftLiner
prevost82
I have 2 Nuheat mats under the tile in our bathroom in the bus. They work well.
Tom Y
I did but in a propane furnace. I am just thinking as another heat source, I was told I would need to bond it to the floor.
Jay and 82, Do you feel it would heat the coach or just make for warm tile to walk on?  Thanks Tom Y
Tom Yaegle
Lin
Tom.
From my understanding, it's all a matter of BTU's.  Electric heaters are usually 1500 watts because that's all you can put on a 15 amp circuit.  That amounts to about 5000 BTU's.  If the mats tell you their wattage, you can multiply that by 3.5 to get the approximate BTU rating.  From there, you have to decide what outside temperature you wish to heat for.  I think probably 10000 BTU's will probably cover you to around freezing. If it gets colder, you can turn on the furnace for backup.
johns4104s
Having been involved in electric heat trace wire and pads,
They can be very dangerous, prone to overheating and FIRE. All the manufactures also carry self regulating tape and pads, same problem.
VanTare
Check this one it is used in some coaches   http://www.goldheat.com
David
VanTare
forgot about this DC model www.warmfloors.com no one I know liked this one because of the DC amp draw
David
TomCat
Quote from: Tom Y on January 27, 2009, 09:58:36 AM
The NuHeat mats will not heat your coach, but when the floors are really warm, I don't seem to mind if the air temp
is cooler than usual.
I'm sorta financially broke, so I just put on more clothes.
HTH
Jay
87 SaftLiner
