Bus Models
Bus Models
Started by Kenny, January 23, 2009, 06:33:13 AM
Kenny
I'm really interested in purchasing another bus and would like something with the long continious looking windows as in the H-series Prevost (see attached photo). Is prevost the only manufacture that has these type of windows? Does MCI or others make buses like this? What years and models?
Kenny
1941 and 1945 Flxible - South Lyon, Michigan
Sammy
Kenny, a bunch of manufacturers offer that "look" today. It depends on your budget,personal preference,etc.I worked with a fleet that had Eagle, MCI, and Prevost coaches in it.
Here's a few links for you to look at, hope it may help.  8)
http://www.mcicoach.com/?reloaded=true
http://www.setra-coaches.com/
http://www.abc-companies.com/models/C2045e.asp
http://www.prevostcar.com/cgi-bin/pages.cgi?page=home
I think just about all modern buses look like that - in fact mine does and it's over 20 years old. The glass units are bonded directly to the steel frame with (on mine at least) flat strips of black plastic covering the join between adjacent windows to give a 'flush' look. If the windows are tinted black it emphasises the 'continuous glass' look even more, and I think if you had to you could probably have larger areas of gloss-black painted steel or plastic between the windows without losing the effect. I'm planning to do this on mine where a couple of windows will be removed as part of the conversion.
Incidentally, one of the styling features of the first Range Rover (1971) was it's black-painted roof pillars, which created what Land Rover later called the 'floating roof' effect, which they have maintained right through to the current models:
Kenny
Guys, thanks for the info. To be a bit more clearer in the description of what I'm looking for, referring to the picture of the Prevost H-series, from the out side of the bus the glass on each window is only separated by a small gap in the outside glass. There is no mulion or any other type of post showing from the outside. If you were to ignore the gaps between the window panes, it would appear to be a continious piece of glass. This is the appearance I'm looking for. Could anyone provide bus manufactures and specific model numbers?
Thank a bunch, Kenny
Ok, understood. I suspect that many (if not most) modern buses are like this in fact, but you'd have to get pretty close to a real bus (rather than photos) to see if the actual glass edges are exposed or if there is something covering them.
If it helps, I'm sure the latest Plaxton would qualify:
Kenny
Jeremy, thanks for the info. I'm looking for years and models that are afordable ($0-$30,000 range)
Thanks, Kenny
Lee Bradley
VanTare
Kenny I was told that Prevost did not use the bonded windows prior to 1998 on the H series they were a framed window.The bonded windows look better to me than the framed windows no rivets or frames
David
Just happened across this 'flush glazing' pic which you might like:
John316
Kenny,
Look into MCI J or later. Most of those have the smooth glass sides (without the window casings).
God bless,
While there are PLENTY of smooth look coaches out there, I beleive you'll find it extremely hard to find one in that price range!
MAK bus sales (the same one that provides this board for us!) has one for sale now! He has listed it on Ebay several times! But again yer gonna have to go out back and dig up more of those old mason jars of $ you got buried! LOL! FWIW ;D  BK  ;D
John316
BK,
You are right about the prices. If Kenny is going for looks, what about a Setra 407 ;) (I think that is the one, I am going from memory which isn't all that reliable ;D ;D ;D). That is a awesome looking bus.
The price will certainly be more for those buses. Our DL3 doesn't have smooth windows, and it sure wasn't cheap.
God bless,
prevost82
If your looking in the 30K range .... your pretty well looking at an early 90's H3 with a 8V92ta.
A friend down the street, with a small charter company, just picked up 2 1996 H3's with ser 60 motors for 45K each, but those are far and few between.
BG6
Quote from: Jeremy on January 23, 2009, 08:26:46 AM
Am I the only one who thinks this looks like a bug in a Pixar film . . ?
BG6
Quote from: Jeremy on January 23, 2009, 11:17:16 AM
Not quite the paint scheme that I'd like, but I'd sure love one of these to convert!
