Another conversion question!
Started by steve5B, January 20, 2009, 03:39:54 PM
steve5B
   Once again I have another question, other than things that physically need to be built in the shell, will everything Else
   fit through the door?  My windows have been installed so that wouldn't work.  I rather not remove the windshield.
   My coach is a 1976 MCI-5B.
   Thanks!  Steve 5B..
WWW.WINNERSCHOICECORPORATION.COM
"It's all in the name the name says it all"
Blacksheep
I found it to be a regular thing to always measure before purchasing what ever it is your looking to purchase!
Ace
Tenor
My MCI 7 has the same door, and everything fit.  However - non RV furniture may be a problem, also think about refrigerators.  Some for RV's are pretty big.  Definitely check a fridge if it is a household fridge.  My queen size bed seemed to be a max fit, so be careful if a king in in your plans.  Shower stalls can be difficult too if they are a fully molded surround and base.
Keep up with questions!  The only question that is wrong is the one not asked!
Glenn
Glenn Williams
Lansing, MI
www.tenorclock@gmail.com
2001 MCI D4500
Series 60 Detroit Diesel
4 speed Spicer
steve5B
  Great answers guys!  Everything that I have so far are RV items.
   Thanks!  Steve 5B..
Jerry Liebler
Steve,
    I have one thing in my bus that wouldn't fit through the door.   It is the closet which is on rollers and normally sits over the bathtub but can be rolled back over a bed, to use the tub.  It had to be assembled inside the bus.  Even the standard sized jetted tub and my kitchen cabinets came in through the door.
Regards
Jerry 4107 1120
steve5B
   ACE, GLENN, JERRY thank you for your replies!
    Steve  5B...
If you use an RV reefer, no problem-if you use a household type, you'll probably have to pop out the windshield.  Good Luck, TomC
Ed Hackenbruch
We had to take the co-pilot seat out so we could get the foldout sleeper sofa in, it barely made it but was better than having to take out the windshield.
