metal on ceiling
Started by jr6715, October 31, 2008, 02:33:11 PM
jr6715
Does anyone know if I can take the metal of the inside front and back of ceiling on a 4107
jr6715
JackConrad
Pretty sure that is part of the structural integrity of the bus.  Jack
jr6715
that is what I am trying to find out it is not very thick metal
jr6715
Blacksheep
Don't know if this helps or not but I have seen front hump areas of 4107's completely removed and then an eagle cap put in its place. I have also seen the same cap installed and the original ceiling left original.
Ace
Tenor
Are you planning on removing the cap or just looking to change the look of the interior?  The metal ceiling in front follows the roofline quite closely, so besides being able to insulate, there is not too much advantage to removing it.  On my 4905, both front and rear ceiling sections had been left in.  I thought it was neat to still have the destination sign.  Can you tell us more about your plans?
Glenn
Glenn Williams
Lansing, MI
www.tenorclock@gmail.com
2001 MCI D4500
Series 60 Detroit Diesel
4 speed Spicer
JackConrad
Quote from: jr6715 on November 01, 2008, 06:15:22 AM
Neither is the aluminum skin on the sides, but it is structural.  Jack
roadrunnertex
The thin metal in the rear and the metal in the front that you speak of is not structure.
The front I left alone on the sides the center portion I removed foamed the area and reinstalled same.
The rear I removed and foamed the area and never reinstalled just framed the area out with wood and paneling.
Never have had a problem after the conversion was finished.
jlv
Jerry Liebler
This has been discussed before here and also on the gmbusnuts Yahoo site.  The consensus was/is that the 'metal headliner' is NOT structural ,it is installed with non structural pop rivets.  I've removed mine both front and back, insulated under them and reinstalled, however in the rear I did modify part of it to allow rectangular drapes over the stock side windows.
Regards
Jerry 4107 1120
jr6715
Thanks that is what I was thinking but just wanted here from someone who has already did it
jr6715
