Is this an air line?
Started by Jcparmley, November 21, 2019, 02:08:24 PM
Jcparmley
Can anyone tell me what the black "line" is in this picture?  I need to cut those cross beams out but I can't get in there without moving those lines.
1989 MCI 102c3 6v92TA Mechanical
brmax
Its a tough picture, but Yes those look to be air lines coupled along with the green. The black is too difficult to see. The others, well the exact ones i couldn't say, sorry. I would respectfully suggest first doing the wheel blocking several places. It may be a good check to see where your lines are headed in those photos.
In any case first releasing the system air pressure from those lines would most times be a smart thing. Sometimes it's difficult as parts of your air systems can stay loaded for brake, parking etc..
Many times these airlines have colors kinda identifying their group or term. Although many are just the black in both plastic and rubber. It really is a blessing in these colors assigned.
Have a good day
Floyd
1992 MC9
6V92
Allison
lostagain
That black line looks to me like electrical conduit. Don't cut it. Maybe you can move it aside?
JC
JC
Blackie AB
1977 MC5C, 6V92/HT740 (sold)
DoubleEagle
If it is an electrical line, you could use a wire tracer to nail down what circuit (or circuits) it is by testing every line going from the junction box. It also might be a shielded metal line for air. How stiff is it? If it is somewhat flexible, it is probably a wire bundle. Either way, you will have to carefully cut out around those lines to replace the metal channel. Good to see rust in something other than an Eagle.  ::)
Walter
Dayton, Ohio
Quote from: DoubleEagle on November 21, 2019, 07:55:28 PM
Here you go Walter add Prevost just a sample for you
DoubleEagle
And yet Eagle gets the bad rust press! At least Eagle's are more convenient to repair.  :D
Walter
Dayton, Ohio
6805eagleguy
Quote from: DoubleEagle on November 22, 2019, 10:27:58 AM
I'll work on an eagle all day! ;)
1968 Eagle model 05
