A couple quick questions before I drive my MCI for the first time in a while - Page 2
Started by Oregonconversion, July 13, 2017, 09:07:49 AM
Geoff
I knew someone who had a foaming problem with his fan blower oil.  The cause cost him a lot for labor and was actually simple--. someone had mixed engine oil with gear oil in his MCI 8.  Either oil will work but you need to know which one you have before adding oil, or better, change all the oil.  Coolant test strips or a simple Prestone coolant tester for the antifreeze.  If it strong (50-50), just add distilled water.
--Geoff
Quote from: Oregonconversion on July 13, 2017, 09:07:49 AM
What type of oil do I put in the  blower gearbox?
How do I check my coolant?  Also what type of coolant do I use?
 Outside on the front drivers side there is a compartment ( hello fuse panel compartment ) with a  plastic  reservoir with some type of oil. Is that power steering and if so what type of oil does it take?
Thanks in advance taking off in a couple hours
Geoff
'82 RTS AZ
Branderson
I made the mistake of not seeing the sight aperture when filling it and filled it to the top.  Yea...there was a mess when I got to wherever I was going to.
- Brad
Dave5Cs
And a lot of us have done that too. I did it coming back from Las Vegas and the back and engine was covered in 40 weight. I had to pressure wash it and thought I had the seals going on it. I took the whole thing out and rebuilt it and then realized it was only overfilled. Oh well needed new rubbers anyway and now has them plus new seals as well. ;D
Boomer
Why is it that so many inexperienced new bus owners don't make their first priority obtaining a maintenance manual?  And reading it.
'81 Eagle 15/45, NO MORE
'47 GM PD3751-438, NO MORE
'65 Crown Atomic, NO MORE
'93 Vogue IV, NO MORE
1964 PD4106-2846
North Idaho USA
Quote from: Boomer on July 14, 2017, 08:32:53 AM
Probably the same reason a lot of new owners don't take driver training or get air-brake certified.  I don't know what that reason is.  Not implying that is the case here, in any way.
Oregonconversion
 Got there safe and she ran great. Constant maintenance even though  she does not move much does the trick for sure. Thanks for your help everyone.
1977 MC8
8V92 HT740
daddysgirl
I'm glad you made it safely!
What everyone else said...and...
Please don't put oil in the round wiper container. It has air lines that run to the windshield, located just below the emergency fill valve.
I use ONLY 100% ethylene glycol antifreeze. Some newer mixed brands are actually not recommended.
Don't let her idle for long periods without a good run.
Double check the tires
Get the maintenance manual and read, read, read. It will save you time, money, and sanity. :)
Andrea   Richmond, VA
Oregon, I went back and looked at your posts - you've been working on her since 2008, but is that the very first trip?  If so, congratulations!
bigred
Quote from: Branderson on July 14, 2017, 07:56:16 AM
Mine blew that silly little hose that feed's down to the engine causing it to leak right down on that big fan!!! Talk about a mess!!!
Dave5Cs
If you need manuals, engine manuals, Parts books etc. these guys have them. Have no affiliation with this company. :)
http://www.coachinfo.com/
