Trans Fluid Check
Trans Fluid Check
Started by Tikvah, September 22, 2014, 05:36:52 AM
Tikvah
Simple question, but I have to ask to be sure....
I have the Alison 740.  The dipstick has a line for HOT and COLD.  Do I check running in neutral or after I've driven, do I check with it off?
It's been sitting overnight now, so I will check cold, but do I start it first or just pull the dipstick?
1989 MCI-102 A3
DD 6V92 Turbo, Alison
Tons of stuff to learn!
http://dave-amy.com/
Check it running and hot in neutral there is a plug to remove to check the stick if you have doubts about it I use the plug when cold
Ed Hackenbruch
Also make sure the stick is all of the ways in. I have to give mine a 1/4 twist to lock it in place and fully seat, to get an accurate reading.
Tikvah
Thanks, I'll check it again next time I'm moving
1989 MCI-102 A3
Tikvah
Quote from: luvrbus on September 22, 2014, 05:46:16 AM
Why would I check the stick?  Don't understand.  I just pull the dipstick.
1989 MCI-102 A3
I always check the stick these old buses one never knows if they are accurate or not it could have been replaced or broken off over time
If you are sure it's the original stick don't bother with checking it, when the 740 hold 10 gals depending on the pan and it takes only 7 gals to fill it according to stick something is wrong
uhmmm ..... because if it is way over full it can blow seals out.... :o
