50DN fell off? - Page 3
50DN fell off?
Started by brando4905, February 13, 2012, 01:55:59 PM
Not much on the front to install a alternator the muffler hides the only pulley guess you could run off the ac drive from the fan drive,there is one left on the rear but has no drive and those are impossible to find what I am trying to tell you Brandon you are just about stuck with your set up the way the power steering ,compressor and  the alternator are mounted on the 4905
brando4905
Clifford, that's what I was afraid of. Hopefully if I put a reman 50dn on there it will be trouble free for the rest of my bussing. Should have looked into it last year when we inframed it.
1980 GMC H8H-649  8V71/V730 Marion,NC
"The highway is for gamblers, better use your sense" -Dylan
Sean
Quote from: brando4905 on February 16, 2012, 05:05:38 AM
... which seems to be a great deal if it is really a new alt.
It says right in the listing that it is a reman.  But it is still a great deal because there is no core charge; you can easily pay that much even with a core.
RickB
What about using the fiber gear instead of the steel gear to prevent a lockup in the future?
The 50D uses a planetary drive a gear running in a gear
brando4905
Well the magic of this board shines through again! Just wanted to post an update that after replacing the 50dn and repairing a wiring mess........ my bus is back together and safely home again!! No gear damage form the alt. falling off.
A big thank you to Lin!! He hooked me up with a perfectly good (rebuilt awhile ago, but not installed) 50dn alternator. Thanks again Lin.
Check your alternator nuts and bolts.  :o
