4106 Rear Engine Lid - Modify for Jakes??
Started by OneLapper, July 19, 2010, 12:47:46 PM
OneLapper
Can anyone post a picture of what they have done to the engine lid to clear the tall valve covers needed when you install Jake Brakes on a 4106??
Thanks!
OneLapper
1964 PD4106-2853
www.markdavia.com
I have the same situation with my AMGeneral transit.  When I installed my Jakes, I got the one piece aluminum valve cover.  I simply cut out the existing door cover and let the valve cover be exposed.  I painted the valve cover gray to match my bus.  I like the look.  If you do use the aluminum valve cover, you could have it polished-that would look good to.  A side line to this is the now extra hole in the engine hatch for the valve cover makes for more air circulation.  Good Luck, TomC
Chopper Scott
James77MCI8
Check with R&M fiberglas, I believe they make a tailgate with a bump in it just for this purpose.
77 MCI 8
8V-71 4 spd
Bill B /bus
On a Buffalo, I used the leftover Al skin from the windows cutout and fabricated, OK so I cut and fit but no welding, a bump to cover the engine and keep the rear cover whole. When the bump was welded I riveted it into place. Looked fine when painted with the rest of the bus.
Bill
Bill & Lynn
MCI102A3, Series 50 w/HT740
OneLapper
Quote from: Chopper Scott on July 19, 2010, 04:42:11 PM
You might give this gus a call.   :D
Now that guy has some serious issues!!  I love the way he used the garbage cans, though!!!
OneLapper
1964 PD4106-2853
www.markdavia.com
OneLapper
Quote from: TomC on July 19, 2010, 02:50:14 PM
TomC,
Did you use the block off plates for the vapor seperator and oil fill neck?  I've been waiting weeks for them, supposedly the DD dealer can still get them but I haven't seen them yet!!
I know I have to cut an opening in the door and I like the idea of just leaving a hole.  If I trim it out closely it might be less noticeable than boxed bump-out.
Thanks guys!
Mark
OneLapper
1964 PD4106-2853
www.markdavia.com
Mark -
Check your inbox at markdavia.
Should help.
OneLapper
Quote from: RJ on July 19, 2010, 10:52:11 PM
Mark -
Should help.
Thanks RJ!  Wow!  What a great a collection of photos!
OneLapper
1964 PD4106-2853
www.markdavia.com
Here's a picture of my bus, but with the old stamped steel valve covers, but with Jakes.  Good Luck, TomC
JLL
I bought a new cover from R&M in Oregon.  It Make a real nice job.
JLL
