Inverter install - ground cable?
Started by bevans6, July 01, 2010, 02:50:58 PM
Is it best practice to locally ground the negative DC power cable to chassis, or to home-run it to the batteries?
Thanks, Brian
gumpy
Your inverter negative, battery negative and chassis ground should all come to one common ground point on the frame. Weld a stud and connect them all there.
I prefer to home run the negative for a high draw device like an inverter.
I like the common stud idea, and used it in the coach.
