Ceiling Insulation
Started by buddydawg, December 16, 2007, 02:02:05 PM
buddydawg
I was working on the bus today and removed some of the ceiling panels which I am planning to replace.  The factory insulation is all in good shape sealed in plastic and lightly glued to the exterior skin.  I removed the insulation in the walls which was deteriorated.  I am going to replace that insulation with either foam board or spray foam. I was surprised that the ceiling insulation was in great shape. Should I save it? Replace it? or what?
1972 GMC T6H-5308A #024
1984 Eagle Model 10
Brandon Stewart - Martinez, GA
JackConrad
Your choice, but foam (sheets or spray) will have a higher R value.  Jack
Highly recommend spray foam-it will quiet everything and stiffen the walls and ceilings.  Good LUck, TomC
