Bus Tachometer ? What kind, Who has one ?
Started by superpickle, May 01, 2007, 09:45:54 AM
superpickle
My bus has NO tach. I would like to put one on it.
It has NO Fuel guage either..  :o what can be done.. besides a Stick down the spout  ;D
Thanks: Pau.....  :-*
Support Global Warming:
Drive an SUV.
Dallas
Paul,
The Tach I used is a 4000RPM electronic marine tach from VDO. I used a Detroit Diesel Tach generator to drive it because I still have a 12V generator, not an alternator.
Your bus should have a huge alternator on it with one terminal marked "R". You can run many of the electronic tachs from that terminal. I believe you'll have to set the tach for 12 pulses, but I could be wrong.
Isspro, VDO, Keinzle, Stewart Warner, and many others make a tach available.
I hope this helps.
Dallas
All the Setra's I've ever been in have them! All though the other day when we were having trouble with the tach in the 45'er I called Setra's tech support # and the guy told me they'd quit putting tachs in them because of all the headaches they caused? ? ? So I dunno what's up with that! But As Dallas points out they are hooked to the "R" terminal on the altenator, as to what setting. I dunno! BK  ;D ;D
ChuckMC8
Super-Pickle: What kind of bus do you have?
RTS/Daytona
Detroit Diesel Delco gear driven 50DN
   270 Amp 24 volt alternators "R" Terminal hookup
   The "R" terminal output is 12 volt -
   Most  6V92TA's are: (2.93 gears & 6 pulses per Revolution=17.58 pulses/rev)
   A few  6V92's can be(2.75 gears & 6 pulses per revolution=17.7  pulses/rev)
   Older GMC 8V71's can be(2.29 gears & 6 pulses per revolution=13.74 pulses/rev)
caution - The action of some regulators do make the Tack "bounce a little" when changing charging modes
Pete RTS/Daytona
LegalEagle82
Anyone know what pulse settings I might need/have with an eagle/ 8v71 / 5 speed manual, as I don't know my gear ratios at this time.  I wouldn't mind adding a tach also.
Thanks...
Legal Eagle
Nashvile, Tennessee
82 Model 10 8v71
95 Model 15 60 Series
superpickle
Quote from: RTS/Daytona on May 01, 2007, 05:55:32 PM
Pete RTS/Daytona
Ya know, I DO have a Pulse problem in the power somewhere. The lights Puls, the Speedometer Pulses ??
I do belive shes a 6V71, could be Wrong, and she has a power problem on hills.. Verry slow.. not much Get UP and go off the line.. ??
Paul...
Drive an SUV.
Even though I have the 50DN and did replace the regulator with a digital one, it still pulses, although quite a bit less than with the transistorized regulator.  I have a mechanical drive off the blower that I can use a synchronized generator for the tachometer. I believe it would be the most accurate.
I too did not have a fuel gauge.  When I pulled the fuel tank to install the intake and return for the generator, I really lucked out in that there were two 5 screw round panels already to go.  I modified one for the generator pickup and return and bought an adjustable fuel sender that screwed right into the 5 hole mount.  Would suggest a zero voltage being empty with full voltage being full-are the simplest.  Good Luck, Tom,C
muddog16
TomC,
Where did you get your digital regulator for your DN50?
Pat
Pat
1982 Prevost LeMirage
8V92TA/HT754
