Installing a base plate and wiring for TOAD - Page 3
Started by Branderson, December 06, 2018, 07:19:42 AM
Dave5Cs
GM made them for the front wheel drive cars so they could be towed but to many were not working correctly and the 1/2 shafts were getting messed up so they discontinued them for FRont wd cars with 1/2 shafts.
Mine is 4wd, so I put the transfer case in neutral.
Geoff
My current toad is an '05 GMC Canyon crew cab 4wd.  It was designed to flat tow-- you put the transfer case in neutral, the shifter in Park (automatic), and you pull the key out.  The steering remains free, the key is in your pocket, and the odometer does not add milage.  No fuses to pull.  Then the newer models came out with electric assist power steering and ruined everything.  But that's okay, I'm not planning on buying a new truck.
Geoff
'82 RTS AZ
