Cruise Control ?
Started by rdbishop, February 08, 2008, 09:24:31 PM
Tony LEE
"The relay was close enough to the Rostra Control module to trigger the module causing it to turn on. Problem solved by adding a diode across the coil terminals (85 & 86) on the relay.  Jack"
Yes, it's always been good practice to add a resistor or diode across coils. Stops a lot of sparking at the switch contacts and reduces EMI.
Having the cruise control is good - I can practice my tap dancing moves while cruising down the highway.
