upholstered panels backing material
Started by H3Jim, September 04, 2007, 01:03:04 PM
H3Jim
I was going to use landau adhesive as it does well in high heat situations.  For foam I am using a dense 1/4 inch closed cell foam thats made for this purpose.
My only question was what to use for the backer board and how to fasten the material to it (staples?).
I was planning on using velcro to hold it to the walls.
Nick, what specifically did you use to hold your panels to the ceiling?
Jim Stewart
prevost82
Jim ... I use 1/4 Luan, painted both sides, with 1/2 closed cell foam glued to the luan, on the face and edges, then Naugahyde was stretched over the foam and stappled on the back side.
Ron
FloridaCliff
Ron
Did you use 3M dual lock, christmas tree or some other sort of fastner to hold them up?
Cliff
Mark Twain
prevost82
Hi Cliff ... no I did. As you can see in the picture I have a dropped centre section, the A/C comes out along the edge of the center section and the return is under the mirror, see PDF attachment. Because the ceiling is in 3 setions I could hide all the screws.
FloridaCliff
Ron,
Very clever install!
Thanks for the explanation of how it all functions.
Cliff
Mark Twain
prevost82
Yea ... it took a little head scratching .... ;D ... I ran all my electrical in the ceiling so I wanted access to it, getting it all to work and look good was a challenge
Ron
jlaney
hey jim
just got the ceiling up in the prevost and looks nice. i use the 1/8 th inch thermal board finish on both sides, glued 3/16 th closed cell foam same as the landau tops for cars. then glued the vynil onto the foam. so far it is not warped on me, thanks j.t
j.t. laney  tyler texas 1980 prevost lemirage
Quote from: H3Jim on September 05, 2007, 06:34:48 AM
Hi jim,
3M Duel Lock   3"x1" every 10"  the duel lock has good adhesive but, I still stapled it on both ceiling and panel. It's real hard to get that
stuff apart.... I also left my emergency hatches in place, they are cleverly hidden by my panels if needed.
Quote from: prevost82 on September 05, 2007, 10:21:34 AM
Ron
Hi Ron,
Real nice job... I like the effect!
I used all the same as you with the exception of 1/4" foam instead of 1/2".
