LED lights - Page 2
LED lights
Started by DebDav, August 20, 2007, 10:33:51 AM
JackConrad
Bob,
   When we installed our LED turn signals on the front and rear, we left the 3 incadesent side turn signals on each side.  We did not change our flasher.
Richard,
    Not sure why the link did not work try www.waytekwire.com and enter part # 47940  Jack
Quote from: NCbob on August 20, 2007, 05:30:25 PM
Jeremy, I have a question...but don't I always?  I'm going to be mixing LED's and incandescents when Fred Hobe installs my custom rear lights (all LED) this fall.  For the turn signals I'm still going with the incandescents for the front and the LED's in the rear.
I have the option of using LED's in the front then I suppose I would need the LED flasher...but unless I do will the current flasher trigger both the fronts and the rear's?
Bob
My understanding (and I stress that I don't have any practical experience) is that you can retain your existing flasher unit if there is still sufficient resistance in the circuit after fitting the LEDs - that resistance could either come from keeping some of the bulbs as incandescents, or by fitting an additional resistor into the circuit. It could be that if the resistance of the circuit changes slightly the flasher will still work but the rate of flash will change.
Incidentally, the supplier who I am using only lists 12v load resistors / flasher relays - which isn't to say that 24v versions aren't available, just that I haven't come across them.
Stan
I think Grote (plus other manufacturers) have flashers for every conceivable combination of lights. Check out their website and order through a local dealer if not in stock.
http://grote.com/product.php?product_number=44010
DrivingMissLazy
I found a heavy duty motorized flasher that flashes the same speed, regardless of the load. It works great, especially when you connect a trailer or toad to the coach.
