where can a guy get a pair of radiators ?
Started by Craig R, December 05, 2023, 03:26:15 PM
lvmci
Here's the 2 24volt fans on their own frame with their own 24volt thermostats that turn on atc180°...
MCI 102C3 8V92, Allison HT740
cutnhorse
 You have a part number, manufactur on those fans, im putting a 8v92 in a model 8 , thinking of taking one of my original radiators, mounting down there on the side in addition to putting the big rad s in the original holes, just had the original one recored a few years ago
lvmci
When sizing electric fans the higher the amp draw the better they have enough power to move the air ,6 amp fans are not much, Derale makes a good set with their high amp motors they will move the CFM as advertised but they are not real cheap . I found out the small low amp fans will not move much air in the heat and high altitude's when you need it the most. They were designed to have help from the front air flow not drawing air from a dead space like on a bus just take a look at the electric fans  used on the Prevost and MCI now.
Quote from: luvrbus on December 31, 2023, 04:45:53 AM
Quote from: Van on December 31, 2023, 05:40:51 AM
Buy 8 of those Bosch fans will set you back some big bucks ,8 electric fans replacing 50 hp from a engine driven fan has to cost
Quote from: luvrbus on December 31, 2023, 06:41:40 AM
Don't quote me but somewhere in the $10,000--$14,ooo range. You'll need the upgraded Bosch alternator also😉
Now you can shave some bucs here. First the fans (not the toy ones) then obiously a custom shroud (s), wiring sensors, relays etc.
A radiators ability to cool is limited by an engines efficiency level as well as the operators ability to keep his/her foot out of the throttle when required.😮 Otherwise you're jus pissin' in the wind.
Remember your 7 P's
