Side Aisle or Center Aisle
Started by Gary Hatt - Publisher BCM, July 09, 2023, 06:25:21 AM
Quote from: luvrbus on July 14, 2023, 07:20:49 AM
Every RV now is center aisle because of the slides but you never see the bathroom on slides wonder why ? must be because of the plumbing, mine has 2 large living and kitchen slides then the bathroom has none then bedroom has 2 slides, I still don't like pocket doors I have 3 in that small area with a large open curved shower
I have seen whole kitchens on slides, so plumbing for those i.e. smaller flexible hoses seem to work, but I would always be concerned that eventually...
Larger sewer hoses would be harder to get a good flexible hose, but someday they probably will, thanks to Nasa. :-)  But the kinking and flex ridges could be a problem for anything except for a macerator toilet as I have.  My toilet exhaust hose (if that is what you want to call it) is flexible and is only 1-1/4" in diameter so that is probably doable.  But I pity the RV Mechanic that will get the job of a busted sewer flex hose in an RV that he has to crawl under to fix, but they probably do this all the time.
Even if I had the money or know-how to put a potty on a slide in a bus conversion, this is probably not something I would do until a better solution for waste comes along.
1999 Prevost H3-45
Jim Blackwood
If you used a slip joint and 2 pivots with several feet between them longitudinally it could be done in a pretty reliable manner.
Here is a large split bath I saw recently.  Obviously, a Split bath is about a large bathroom as you can get in a Bus Conversion.
1999 Prevost H3-45
