Balancing Beads? - Page 2
Balancing Beads?
Started by Glennman, June 12, 2023, 12:36:24 PM
Jim Blackwood
That video is useless. Nothing but marketing. What do they do to affect the balance?
Common sense says they go as far from center as possible. Tires do tend to be not perfectly round and that would create an imbalance, not cure it.
Quote from: lostagain on June 14, 2023, 08:33:58 AM
A good tire doesn't need balancing, especially on the drive axle.
When Les Schwab in OR installed 8 new tires on the Country Coach they used nothing but the balancing dot on the tires,I ask he said it was a waste of $320.00 to balance they would be fine and they are.I asked about the beads and he said no with the Bendix TPMS tire system inside the tire it would destroy the sensors,he wasn't all that hip on beads though period  :^
Add a pint of antifreeze blend.
Quote from: chessie4905 on June 14, 2023, 11:32:18 AM
Some say golf balls.I bet the golf balls work good when the cover wears out and they unwind inside the tire  :D
Utahclaimjumper
  I have been using beads for 20 years and they are the best at keeping the tires balanced for the life of the tires,, no down side..>>>Dan
Utclmjmpr  (rufcmpn)
EX 4106 (presently SOB)
Cedar City, Ut.
72 VW Baja towed
Jim Blackwood
How do they work? I want to know the details. Without a suitable explanation that makes it clear how they compensate for the imbalance it is still all nothing but snake oil.
dtcerrato
Quote from: Jim Blackwood on June 15, 2023, 07:12:34 AM
Jim try this one, the proof is in the pudding. We've used this method for 20 years. No issues and tires stay balanced even after rotating.
https://www.centramatic.com/wheel-balancing-educational-video.rhtml
Dan & Sandy
North Central Florida
PD4104-129 since 1979
Jim Blackwood
OK that's good but I want to know WHY the balls go to the light side. What is the force that does this? I can see from the video that it does and I believe what I'm being told by you who have tried it, but I still want to know why. Someone besides me has to have questioned this because it is a contrary result. Intuitively it is wrong.
dtcerrato
A couple of informatory paragraphs I found on the web...
The beads spread out as the tire rotates, drive by the tire's rotation. When the heavy spot on the tire moves the wheel in one direction, momentum carries the beads the other way, until they spread out in a "balanced" layer. that's a layer such that spinning the tire doesn't cause vibration - aka balanced.
Centrifugal force is the natural force that distributes the beads evenly around the inner liner of the tire, while the inertia is what positions them where they need to be. This happens when the upward and downward motion of the suspension, and vibrations of the wheel imbalances force the product to do so.Oct 13, 2020
Dan & Sandy
Quote from: dtcerrato on June 15, 2023, 05:09:26 PM
I can't see that theory working at all speeds,I seen the tire companies dump a 12 oz bag of beads in tires before that a lot of lead weights
DoubleEagle
The balancing dot on the Toyo's sounds very interesting, how many other makes do this?
Walter
Dayton, Ohio
Quote from: DoubleEagle on June 15, 2023, 06:43:10 PM
Have no idea Walter .some wheels have a dot or a notch you match with the dot on the tire
dtcerrato
Quote from: luvrbus on June 15, 2023, 07:32:16 PM
So I would assume the dot denotes the heavy side so if you put the dots 180° apart that would lend to the most balanced condition? Or something like that?
Dan & Sandy
Gary Hatt - Publisher BCM
Yeah, you would think they would come balanced from the factory...aye?
1999 Prevost H3-45
Utahclaimjumper
I really don't know or care what makes them work as they do,, I do know that when I replace a tire I always have beads installed..  When first starting out with a new tire I can feel some bouncing and also feel it slowly going away with a few miles,,, never to return during the life of the tire,, good enough experience for me..>>>Dan
Utclmjmpr  (rufcmpn)
Cedar City, Ut.
72 VW Baja towed
