What do you do to increase your bus's fuel mileage?
Started by sandra@BCM, July 21, 2022, 01:21:43 PM
Quote from: TomC on July 27, 2022, 08:57:42 PM
Let's see-you have 315/80R-22.5 that is 491rpm with 4.56 rear end gives 2234 in 4th, 1656 in 5th, 1432 in 6th. At 55 you would be at 2047 in 4th, 1515 in 5th, 1310 in 6th. Sounds good to me. Good Luck, TomC
I must have different gears I am at 1300 @65 mph in 6th ,I am not to worried about saving a 10th of a mpg for safety I an not going to drive 55mpg on the interstates with trucks coming up behind at 75 mph.My cooling fan runs off a PTO on the transmission if that makes a difference
robertglines1
I have 3:07 gears and a eaton autoshift. haven't needed the 10th gear yet to run with traffic. If I did it again would go with 3:73 as a more pleasurable drive experience. you don't creep much with 3:07. example backing trailer.   Bob   ps my salvage shell had no hogs head. so, I could do as I choose.
Lin
I always found that leaving the toad behind helped a lot.
Cliff-that works out to be exactly 3.82 gears. Actually your 65mph speed is a perfect rpm.
dtcerrato
Quote from: Lin on July 28, 2022, 11:26:22 AM
Unless you use the bus to make runs the toad would do!
Dan & Sandy
North Central Florida
PD4104-129 since 1979
Lin
dtcerrato
We're leaving the toad we carried up to Alaska garaged here so on future trips we have the option to fly. It'll be a bitter sweet driving the bus home to FL bareback.
Dan & Sandy
