4104 vibration at speed - Page 3
Started by Nova Eona, March 15, 2022, 08:58:53 AM
fortyniner
Any recommendations for a torque multiplier? Would be handy for lug nuts.
Ive heard about seat issues on some of these Hemis especially if it overheats. This one is a 2011 and valves/seats are still in good shape. One lifer roller is seized and its cam lobe is rounded off.  Cose examination of other lobes shows a few with pitting starting on nose. It reminds me of a wheel bearing race that's starting to fail. Lifter rollers for those lobe are still ok.  I suspect its cam lobe breakdown that starts the process and lifter failure is the last stage.
Don't know if this is advisable on a 4101 but we tracked down driveline vibration on a car by putting axle on jackstands and running it at highway speed. Ours was a bad ujoint install causing drive shaft vibration at tranny.
Tom Phillips
PD4106-453
PD4106-2864
87 Alfa Milano
93 Range Rover
87 190e-16 Mercedes
92 Jeep Comanche
dtcerrato
Our torque multiplier isn't the lug nut style. It looks like a beefy socket ratchet with a 2' handle. It's 3/4" input & 1" output square drives.
The Hemi valve seat issue mostly disappeared with the 2009 model & newer. There were specific issue with 2011 models but don't know the details - wonder if the cam/lifter is part of that?
If we allow our bus drivetrain (drive shaft, & universal joint grease fittings to get deprived of regular lubing - the drive line will develop a vibration - especially on turns under a load. With regular lubing it runs smooth. I would contribute this to worn parts (excessive clearance) in the U joints and specifically the driveshaft slip spline yoke.
Dan & Sandy
North Central Florida
PD4104-129 since 1979
also a worn out slip joint can cause it. Find a bigger drive shaft shop that can chuck the whole shaft assembly on their lathe.
sledhead
nut buster
removes bus tire lug nuts like they are fingner tight and no more air compressor or air lines and works great on all nuts
https://www.milwaukeetool.com/Products/Power-Tools/Fastening/Impact-Wrenches/2764-20
dave , karen
fortyniner
Right been eyeing one of those. But how to torque them back down is still a problem for me. I mean a 5 foot bar and digital torque adapter is how I did it last time but its no fun.
Tom Phillips
PD4106-453
PD4106-2864
87 Alfa Milano
93 Range Rover
87 190e-16 Mercedes
92 Jeep Comanche
Might as well go with their 1" battery wrench. 1800 lb. ft. Torque.
I have Harbor Freight's 3/4" version. May not be quite as high torque as the fuel, but lots cheaper and works fine on my lug nuts.
