happybuy diesel air heater - Page 6
Started by chessie4905, November 05, 2021, 05:50:07 PM
dtcerrato
Awesome! Clifford is going to give it a go with a CDH... I love it!  :^
We're doing major surgery on the large bottom compartment to make room for the second CDH. We're doing away with the 12 gallon tank on the electric aux. air compressor to relocate the compressor w/o the tank. A real project underway paving the install of the second heater. Just pulled the trigger on ducting & registers for the second heater - direct from China! supposed to have it all before Christmas - Lol, we'll see...
Dan & Sandy
North Central Florida
PD4104-129 since 1979
Quote from: dtcerrato on November 13, 2021, 05:37:35 PM
LOL I have nothing to install the heater in though is my  problem plus it is going to be 91 here on Sunday
Dave5Cs
I'm  going to buy a Lavener pro. They are more expensive but have a good reputation and lots of assistance from Lavaner for any issues. Vendors have good reviews also. Yours is the all in one?
Cliff, be sure you have full 12 volts, consider heavier wire if lengthy source. Lots of help on Faq page. I've  been reading many posts about issues some users have, which 60 percent are self inflicted. Oh, and don't  use green fuel line. Common issue of cracking and sucking air in time.
I don't need  hoses I bought a self contain unit with a tank to play around with
Quote from: luvrbus on November 13, 2021, 05:00:28 PM
Is there a market for a heater used for a test only :^
I might have a home for it lol
Quote from: Van on November 14, 2021, 09:59:37 AM
I thought about you lol since it has green hoses from the tank to the unit you may not want it  :'(
they recommend replacing with 2mm opaque tubing. Some haven't had an issue with it yet. Since you are just going to test it, not a problem
Quote from: chessie4905 on November 14, 2021, 01:17:06 PM
It looks to be silicone hose I wonder what causes a problem ?
reports indicate micro cracks leading  to air bubbles in fuel line.
Get approved to the Facebook Chineese diesel air heaters. The one with the most followers. you need to request to join, not a big deal.A wealth of information there. I've  learned a great deal so far.
funny- they describe the instructions that come with most of them as being written in Chinglish.lol That's where the forum is beneficial if having issues or questions on operation. These things are extremely popular in the UK. Many are installed in cars. vans, tents,sheds, boats, etc.
Quote from: chessie4905 on November 14, 2021, 01:27:56 PM
Instructions  are not much I am still working on the "there should be no gas in the exhaust" wth
dtcerrato
Two more CDHs just delivered! One will be a second unit for the bus the other will be spare parts - both for total of $244. I notice the fuel tanks changed from 10L to 15L oh boy!  :)
Dan & Sandy
Quote from: dtcerrato on November 17, 2021, 05:22:28 PM
What little time I played with mine I  am not buying into a 100 hrs run time on 2-1/2 gals
dtcerrato
Not on high nor in the mid to upper heat range but seems it will run forever on low to minimum heat and very quiet almost silent. At $120 a unit it would cost more than double that for all the serviceable parts to repair a unit. Can't purchase the fan motor alone, only as a unit including motor, fan, and end casting. Cheapest I seen that part is $50 to over $100. I know a bus nut that's on the fourth year full timing with only a CDH and no issues.
Dan & Sandy
