Any suggestions for greasing my own bus?
Started by belfert, August 19, 2021, 09:39:21 AM
Brian, do you have any battery tools? Get a grease gun that uses the same batteries. That way it won't poop out halfway through the job and need to wait to recharge.
Jess sells 22 ton pin type jackstands and aren't anywhere close to $600. Should be available at Napa or other places.
usbusin
Gary D
With his suspension he doesn't need jack stands,all he has to do is take the weight off 1 wheel at a time to grease the king pins  a 12 ton jack will do that.? why 22 ton jack stands for a 12,000 lbs front axle  ::)
usbusin
Lots of 12 ton bottle jacks at $119. and up at Napa.
Shoot, maybe a 6 ton (12,000lb) would do it?
Be sure to block the bus before getting under!
Gary D
Even with the axle raised with a HF air operated bottle jack, is there enough room to slide under and do steering, Pittman arm, etc? Guess he doesn't have ramps.
Quote from: chessie4905 on August 19, 2021, 05:40:03 PM
Yes, there are cheaper jack stands, but I buy made in the USA when possible.  I found some open box 25 ton Hein-Werner stands on Ebay for under $350.  I had the same thought as another poster of just using wood instead of jack stands although I might very well need the jack stands again.  I already have an air operated jack that will lift the bus.
I have lots of Makita cordless tools including ten batteries, but I would be willing to go with another brand if their grease gun is significantly better.  I also have some Dewalt 60 volt/20 volt batteries and some Ryobi batteries.  Dewalts makes a cordless air compressor that Makita doesn't make and Ryobi sold a cordless miter saw long before Makita ever did.
Quote from: chessie4905 on August 19, 2021, 06:29:35 PM
My Dina has torsilastic suspension and it has tons of ground clearance for some reason.  People who have seen the bus say the torilastics still have plenty of life because the bus sits so high.  There is enough clearance to crawl underneath and get to things.
I have never blocked the bus if it isn't jacked up because there are no air bags to drop the bus on me.
Quote from: belfert on August 19, 2021, 06:35:01 PM
You should be able to buy OTC for around $200.00 a pair
dtcerrato
We carry a standard hand pump and a pneumatic gun with flexible hoses and 7 tubes of grease plus the coveralls.
Dan & Sandy
North Central Florida
PD4104-129 since 1979
sledhead
I have a milwaukee 18 v grease gun and it works great in the bush but on the coach I like to use the air grease gun when it is at home
like Dan I made up my own wood blocks screwed together and round all wrapped and screwed around them as well . so easy and inexpensive and all of them are the right height
dave
dave , karen
edvanland
I made my own ramps out of 2x12 4 high screwed and glued together. Suggest you put a rope handle on both sides of each one makes it a lot easier to get out and also carry
Ed Van
MCI 7
Cornville, AZ
lostagain
If you only grease the bus once a year, wouldn't a $30 hand grease gun be enough?
JC
Blackie AB
1977 MC5C, 6V92/HT740 (sold)
windtrader
That's my take on lube guns!
Quote from: lostagain on August 21, 2021, 04:27:52 PM
Don F
1976 MCI/TMC MC-8 #1286
Fully converted
Bought 2017
dtcerrato
I agree but the pneumatic grease gun only needs one hand to grease. A regular conventional grease gun requires both hands on it to grease - major difference - we use both...
Dan & Sandy
