Bus floorplan layout resources?
Started by wolrah, March 01, 2021, 09:26:13 AM
Layout your floor plan with regards to your bus design. Where you want the water tank (mine is under the master bed to keep fresh water plumbing above the floor), gray tank, black tank, propane, generator, etc. I had to modify my floor plan a couple of times to get everything positioned correctly. Good Luck, TomC
Remember that he stated he was in the initial planning stages of a conversion. Maybe he took my suggestion and is out looking for a shell. He could be busy with something else right now. Not everyone lives on here.😅
Gary Hatt - Publisher BCM
We have over 150 back issues on our website that all subscribers have access to and we are adding more back issues weekly.  Every issue has a featured bus and shows lots of photos of the inside and many have a floor plan.  I encourage anyone considering converting a bus to review as many of these back issues as possible before laying out your own to get as many ideas as you can.  This may potentially save you hundreds or thousands of dollars in changes you may require later.
Click here to see the back issues.
https://www.busconversionmagazine.com/back-issues/
1999 Prevost H3-45
Utahclaimjumper
 Another thing easily missed is the standard placement( in 98% of RV parks today) of the power pole and waste openings on the drivers side rear of the coach .>>>Dan
Utclmjmpr  (rufcmpn)
EX 4106 (presently SOB)
Cedar City, Ut.
72 VW Baja towed
