Fuel tank
Started by petarm1, January 10, 2020, 04:55:33 AM
Brian Diehl
Interestingly enough my fuel tank had almost no sludge in it ...
Yours may be similarly clean ...
My 102C3 had a few worn through spots on the bottom of the tank specifically where some putting and galvanic corrosion was. I removed the tank, power washed the inside and outside to the point of it almost being food grade, then took a wire wheel to the places I wanted to repair. After everything dried in the Texas sun, I wiped the repair locations down with alcohol and used the best two parts JB weld I could find. Longer set time equals better fix. I also did something while applying the JB weld, I put a gentle vacuum on the tank using a shop vac and a rag. This actually pulled some of the JB into the holes while it set. I then removed the vacuum and JB welded again. This was four years ago and haven't leaked a drop since.
petarm1
How does the panel come off so i can remove the tank. Do i have to drill the rivits
1989 mci 102c3  6v92   7 speed manual / 1999 mci 102dl3 60 series b500r
Prince rupert bc
Two bolts inside top corners and lift it out.
If i remember correctly and it's the same as an mc8.
You have to find the tank hold down fasteners too, once the door is off.
Happy coaching!
Buswarrior
petarm1
Prince rupert bc
