Black tank odor - switch to macerating toilet? - Page 6
Started by belfert, October 14, 2019, 08:03:48 AM
Toolman
Denning Hi-Deck
6V92  7speed
Jcparmley
Toolman do you have a pic of the air vent going to your engine air intake?  Not quite sure what you mean by a Venturi.  Thanks
Quote from: Toolman on October 17, 2019, 01:48:25 AM
The answer is very simple ;D, I pump a small amount of compressed air from the bus into my tanks while driving
I also vent my tanks ( 40mm ) back to a venturi in the engine air intake, before the air cleaner.
I also have a small fish tank air pump that I can use if stopped for some time. the air is pumped in the bottom of the tanks and bubbles up through the contents = no smell   ;D
1989 MCI 102c3 6v92TA Mechanical
Toolman
No photo, I would have to take the air intake apart. It is nothing more than a 1-1/2" pipe welded into the air intake. The pipe protrudes into the airstream alittle with the upstream side of the pipe maybe sticking out 1/4". the other side is level with the intake. Simple way to create a low pressure area = suction. Hope I make sense. :) It was already in the bus to draw air flow through the bathroom as has been talked about.
Denning Hi-Deck
6V92  7speed
