GM Dash Light - Page 2
GM Dash Light
Started by richard5933, September 10, 2019, 11:53:00 AM
richard5933
Quote from: chessie4905 on September 11, 2019, 03:55:28 PM
Most items are in the parts book.  Finding them sometimes requires advanced sleuthing. Then, in the service manual, where is the fuel tank strap bolt torque specs?
I give - can't find it. Thought it'd be in either the 'body' or 'fuel' section, but I cannot find it.
Not there. Also no info on removing and installing fuel tank, although it is pretty easy.
richard5933
Quote from: chessie4905 on September 11, 2019, 06:44:12 PM
Trick question then. Surprising the info isn't in there somewhere, as it's pretty complete (at least compared to what I hear about the MCI manuals).
There are two low air pressure warning switches tied into the push pull valve for parking brake. They are up in the area where all the lines go vertical where the floor level changes. Usually are accessible from inside of coach on face of riser last step. My conversion had this area covered over. Discovered them from underneath with a stethoscope. Of course they were both leaking some.They were next to impossible to get to. After several hours of reaching with all kinds of wrenches and screw drivers to loosen terminals, finally got them replaced.
