SOLVED: Bus Won't Air Up - Page 4
Started by GnarlyBus, April 06, 2019, 03:43:14 PM
The discharge muffler on an MC9 should catch "normal" amounts of oil. So long as you "Drain Daily" ... only a really bad compressor will get oil to the drier.
The desicant will withstand a little, since oil mist is a reality of operation. But a soaking will render the "desicant" function useless.
What are you getting out of the "Drain Daily"?
Happy coaching!
Buswarrior
GnarlyBus
This is the drain daily rear discharge muffler, right? Does it purge on it's own at all? It does have some wet oil slobber evidence.
This is the rear tank drain as well, right?
I'm installing pull cords on my front tanks later and the under driver tank is easy. Expecting lots of junk to come out of the front tanks today and then I can monitor them in the future and see how much is making it past the dryer.
Full-Time since 2015
At least first time, open tank drains and leave them open at least overnight to completely drain any oil / residue.
GnarlyBus
Fired up the bus today and the bus air is working properly again! The air dryer is purging properly again.
I drained the tanks for about 30 seconds each for the first time ever and nothing but a short burst of moisture left the wet tank. Other tanks were just air. Adding pull lanyards so I can be on top of draining these every time.
Thanks everybody for the help!
Also, I added a psi gauge near the discharge muffler to make sure the compressor was cycling.
Jim Blackwood
Thanks for leading the way. I'll be following up on my own system later.
Quote from: GnarlyBus on April 17, 2019, 02:20:14 PM
Manual valve. Feel free to replace that one pictured with something that has a handle.
Mind your shoes and pant legs, there's likely going to be a big mess blasted out of there.
No, it isn't connected to the rear tank. It is inline to the air drier.
