First trip through mountains
Started by richard5933, June 28, 2018, 05:03:28 AM
Geoff
We are debating .059 v. .035. =  .014.  The average thickness of a man's fingernail is .384. When I see damage from valves hitting pistons, it is closer to 1/8 to 1/4 of an inch bend.  It's not from too tight of Jakes clearance from normal use.  Get a feeler gauge and dig out a .014 blade.  I'm not inclined to go measure the cam lobes staying open with Jakes, I just know what works and what fails.  I have mine at ,035 and the Jakes work better with no floating valves.
Geoff
Geoff
'82 RTS AZ
Geoff
Quote from: Geoff on July 01, 2018, 03:43:03 PM
We are debating .059 v. .035. =  .014.  The average thickness of a man's fingernail is .384mm. When I see damage from valves hitting pistons, it is closer to 1/8 to 1/4 of an inch bend.  It's not from too tight of Jakes clearance from normal use.  Get a feeler gauge and dig out a .014 blade.  I'm not inclined to go measure the cam lobes staying open with Jakes, I just know what works and what fails.  I have mine at ,035 and the Jakes work better with no floating valves.
Geoff
Geoff
'82 RTS AZ
LOL I see you changed the .384 to mm I thought that person would have some very thick finger nails over 3/8th inch thick nails  8,really Geoff I don't have any problems with Jakes working at the 0.059 adjustment  a Jake gauge is all I use
Geoff
I don't care either, I had a hot weather bad day yesterday.
Geoff
'82 RTS AZ
Dave5Cs
Quote from: Geoff on July 02, 2018, 09:32:50 AM
How's your back doing Geoff?
Geoff
My back is fine after the operation to dig out all the chipped vertebrae that was pressing on my spine.  It took almost a year for them to operate.
Thanks for asking
Geoff
Geoff
'82 RTS AZ
Dave5Cs
Good remember you were going in. Glad it came out well or at least probably etter than when you went in.
