Look Inside My 6v92 Cylinder Liners (VIDEO) - Page 3
Started by GnarlyBus, June 24, 2018, 03:28:39 PM
The o-rings on a liner in a DD last about as long as a snowball in 115 AZ heat if something other than engine oil was used,the after cooler plugs use a aluminum seal on each and are coated Loctite pipe sealant torqued to 270 ft lbs they don't leak if done right and are a bear to remove.If the liners are drove in with a hammer and board then the o-rings were damaged those should go in by pushing with your hand 92 liners need to be fitted just like a 71 series.Usually it is the upper head on a tilt engine that has the problems for lack of water and cooling
