Broke Down in Victorville, CA - Good Sams is on its way
Started by Gary Hatt - Publisher BCM, March 28, 2018, 04:33:13 PM
Got it fixed Jack.  Only $12,000 and I was back on the road last Friday. Runs like a champ.
1999 Prevost H3-45
Quote from: luvrbus on April 12, 2018, 01:34:15 PM
7 years ago United Transmission was a Allison dealer they built transmissions then to Allison specs so don't put much stock in United used Chinese parts back then.Fwiw 740's don't last behind a series 60 because they run at peak or above the torque rating same for HP rating a series 60 produces.Better find you a drop box that is next  ;)
Yup.  Drop box is leaking in 3 places.  Daniel Lenz called me today to tell me to get it rebuilt.  When are you available Cliff?  :-)
1999 Prevost H3-45
Quote from: Gary Hatt - Publisher BCM on April 17, 2018, 07:14:31 PM
If it is leaking it needs to come out,come on down or up in May and I'll help you,I have a engine swap the 1st week of May ,a Jake installation,Marks 6v92 in his 4104 what ever it takes and 2- 8v92's to rebuild.I can squeeze you in just bring the Tecate it's that time of the year in AZ  ::)
Quote from: luvrbus on April 19, 2018, 01:55:46 PM
Okay Cliff, I will see what I can do.  In the meantime I will order a tractor trailer load of Tecate and send it to your house.  :D
1999 Prevost H3-45
Boomer
I have a rebuilt drop box if it grenades on you in the meantime.
'81 Eagle 15/45, NO MORE
'47 GM PD3751-438, NO MORE
'65 Crown Atomic, NO MORE
'93 Vogue IV, NO MORE
1964 PD4106-2846
North Idaho USA
Quote from: Boomer on April 20, 2018, 09:12:27 AM
Thanks Boomer. I may take you up on it if I don't get with Cliff to rebuild it first as I plan to make at least one of those rallies up at the NorthWest Bus Nuts.
1999 Prevost H3-45
Quote from: Gary Hatt - Publisher BCM on April 20, 2018, 09:51:48 AM
Marks drop box maybe your best bet Gary if the gears are chipped and worn in yours they are pricey if you can find the bull gear lol and that drop box may know it's way to Mohave Valley
