On Demand Hot Water Heater - Page 2
Started by Lifes2short4nofun, March 04, 2018, 03:26:00 PM
Quote from: Geoff on March 05, 2018, 05:48:41 PM...  I have an Attwood water heater that has four heat sources:. Propane, electric, coolant water loop (from the engine), and radiant heat from the engine compartment.  10 or 11 gallons of hot water ...
    Yep.
lvmci
Hi 2short, Jack & Fred have hit on my solution, that solved my flow issues, it was the flow restrictors on the shower head and areator on the bathroom faucet, that kept the tankless from continually firing. The kitchen always had hot water continually, which caused me to investigate, I unscrewed the areator and unscrewed the shower head and continuous hot water. Before I had to turn on both faucets to run hot water. Try my experiment, see if it works, lvmci...
MCI 102C3 8V92, Allison HT740
Lifes2short4nofun
Thanks a lot,  I will try that and see how it goes.
1972 MCI 5B
Gordie Allen
peterbylt,
I have a 110v on demand like you're looking at on Amazon. I replaced a 10 gal. tank. We have a dishwasher, washer/dryer combo, and shower. We're also full-timers. We really love this unit and while we can't do all three activities at the same time, we can shower a and run one of the two others at the same time. Plus we got about 3 cubic feet of additional space. Enough to move cat litter box into the under-washer space.
Augusta, MI
1956 4104
DD 671
dtcerrato
We just love our 20 gal electric for a lot of decades. We service it every 7-10 years by cleaning all the sediment out of it & replacing the annode rod. Once turned off will keep plenty warm for a couple days & more hot water than you can use :-) we also have a 6 gal propane for pure boon docking.
Dan & Sandy
North Central Florida
PD4104-129 since 1979
peterbylt
Quote from: Gordie Allen on March 05, 2018, 09:57:07 PM
peterbylt,
Thank You for the Imput.
On Amazon you can select either the 2.5 gallon $169.99 , the 4 gallon $186.95 , or the 7 gallon $187.53 .
I would certainly get the 7 gallon, The price difference between each of these is only about $18, at $187.53 I consider it quite reasonable.
They are also rated at 12A at 120V, I don't consider that outragoues either.
We currently have a 6 Gallon Propane fired Hot water heater in our Class C and have never run out while taking a shower with that, Although the shower is so rediculously small in the Class C you don't stay in there for long anyway.
Peter
Tampa Fl,
1989 MCI 96A3, 8V92TA
I'd compare the recovery rate between the propane and the electric. May be important.
Geoff
Quote from: Oonrahnjay on March 05, 2018, 07:04:33 PM
    Yep.
I guess "Yep" must mean you have the same system as I do?  Or what do you have?
Geoff
'82 RTS AZ
bigred
When my regular water heater went out on me ,I let a guy from the gas company talk me into putting one of those tankless water heaters in my house.Absolutely one of the worst mistakes I ever made in my life. Words can not describe how much I hate this darned thing!!!
Quote from: Geoff on March 06, 2018, 03:32:47 PMI guess "Yep" must mean you have the same system as I do?  Or what do you have?
     Exactly.  It runs on 120V or propane except that I very rarely need to run it on those because of the heat from the engine warmant.  Compact unit, lots of hot water (and it has a built-in "tempering valve" to take 180 degree water from the engine coil and mix it with cool water to give you regular hot water -- the 11 gallons in the tank becomes 20 - 25 - 30 gallons delivered to your taps.
