Fuel in Oil
Started by Fred Mc, November 10, 2017, 01:07:30 PM
2 psi is a lot more than most think...i would definitely use a secondary regulator...
If I was to do that, and I think it could be a great idea, I would plug the return line (out the back of the passenger side head on my MCI) and put air directly into the head, bypassing the fuel pump.  Probably do one head at a time.  You could use a coolant system leakdown gauge, maybe.
Fred Mc
On my bus (gmpd4106) I have disconnected the line that goes from the secondary filter to the head to apply  air pressure. This is after fuel pump. I also will cap off the return line to tank so it only applies air thru both heads. I have an air regulator from a spray gun that goes down to only a few pounds air pressure as well.
And according to the post I read, if you use compressesd air you should be able to hear it leaking. I also suspect one might have to use soapy water to find the leak(s) -and obvoiusly trying to prevent the soapy water running down into the oilpan.
Regards
Fred
Don't use soapy water. Put diesel fuel in spray bottle and spray/ flood suspected spots. Air bubbles will show.
Fred Mc
