Black tank mounting
Started by pennuja, September 17, 2017, 07:02:13 PM
Quote from: gg04 on September 18, 2017, 09:19:20 AM
Our bus has about 1/2" for 6' run. For commercial and RV parks we used under 2" per 100' for feed and under 1" per 100' for field.
4" pipe is great for 4 bedroom house, or tying a run of spots together, but small house, bus, or RV spot only needs 3" to keep volume of water under poop...
you are right..i misspoke, mine is 3 inch  :P
but the drop is as i said :)
kyle4501
While a macerator pump is not a necessity, it does allow use of a small 3/4" hose to direct the waste up hill as needed. Easier to drain the tank when you aren't limited by gravity.
Sometimes, a splurge expenditure makes sense when you look at the big picture. . . .
