Non Turbo Travel Times Out West
Started by Lin, May 06, 2017, 01:07:02 PM
Ed Hackenbruch
Lin, I-10 to about 12 miles past Quartzsite (exit 31) where you get onto Hiway 60, go thru Wickenburg about 10 miles and get onto Hiway 74 which takes you to I-17. Easy route to do, misses all of Phoenix area. :)   Ed
Lin
Ed, that is an interesting route.  One of the options that comes up on Google Maps is taking 62 from where we live to Parker, Az. Then Az 95 south for a bit and joining 60 there all the way to Wickenburg and 17.  For us, the mileage is less than going down to 10, but I was not sure what those roads and traffic are like.  If they are good 60mpg roads, they would be a nice choice.
It a good route Lin sometimes we go that route from Parker nice flat route through the cantaloupe country
Quote from: Dave5Cs on May 07, 2017, 10:57:06 AM
Clifford talk to my Nav she is always correct. She also cooks my food!...
Don our Bus and a lot of others only go full bore up hills 7% grades at 27 MPH and Blinking all the way....
you gain 1/16th mph if you turn off the 4 way flashers :)
Dave5Cs
Eagle is it the heat buildup in the lens? ;)
Quote from: Dave5Cs on May 12, 2017, 04:13:28 PM
no..hot air rises and tends to reduce traction...which cause drag....which puts a load on the alternator... ;D >:( ;D >:( ;D >:(
Dave5Cs
