High efficiency gas furnace for bus - Page 2
Started by Scott & Heather, June 17, 2016, 04:34:15 AM
Quote from: DoubleEagle on December 08, 2016, 07:16:40 AM
Yep, the heat pumps I had twenty years ago would stop making heat when it got into the lower 40's, but down into the 30's is only a little better. When it gets really cold, heat pumps will not deliver.
I am like on Vern would say on the commercials years ago feel the heat,but Scott has a young child. I know the floor vents in our Trek will burn you if the furnace has been running for a few minutes lol but the heat feels good on a cold morning
The minisplit heat pumps have proven over and over again that they will produce good heat down to 17 degrees. Some of them even less. I have seen this proven more than once. But of course I don't have mini splits. Good info about the freezing condensate. I might relocate the furnace
High pressure systems like a mini split just generate more heat,works that way with anything high pressure makes heat
