I love my new Adco cover!
Started by belfert, December 13, 2015, 11:27:21 AM
Lin
I understand the problem that the local authority will not let you build on a flood plain. I have seen people getting around building restrictions by building tent structures that appear to be exempt from various codes.  They even are made with I-beam construction and called permanent tent structures.
DoubleEagle
For a temporary building, consider a bow-type greenhouse made with galvanized pipe, covered with plastic. I use one that I bought used from a closing garden center that is 66' long and 20' wide. Very wind resistant, and if you use greenhouse plastic, it will last 4-8 years. I put a layer of shade cloth on first, then clear or white plastic.
Walter
Dayton, Ohio
Melbo
Find a company that does spray on bed liners.  Talk to them about doing your roof.  IF and please note that is in CAPS you find a good company they can do your roof so it won't leak.  Then you can stop with the covers and trying to find a way to build where you can't build.  I hope this helps.
Melbo
I had a small leak at my fiberglass and aluminum cap junction so I just went on the roof on a hot day and pressed down some peel n seal from lowes. Awesome stuff. Killed my leaks
bigred
Don't know how long it will last but Flexseal will dang sure plug up a leak .According to their hype,it is supposed to last for years.
Unfortunately, the spray-on bedliner for a roof is $3,000 minimum.  I have checked into it previously.  There is a company that does just RV roofs with a bedliner type material, but they are $5,000 plus travel costs.
My long term plan was to build a garage for my bus, but that will probably never happen now.  I would probably have to move again to build a garage for my bus.  I wasn't aware that the property I bought was on the edge of a flood zone.  There are no lakes, rivers, or streams even close so I never looked into flood zones.  There is a nature area nearby that is full of wetlands and apparently those wetlands are at risk of flooding.  I am on the very edge of the flood zone so I doubt I would ever get any damage.  My house is outside the flood zone.
You can ask FEMA to remove existing structures from the flood zone, but I don't know that you can get permission to build in a flood zone.
niles500
There is no federal law denying you the ability to build a bus port in a flood zone, are you sure it's not a floodway?
(\__/)
(")_(")
- Niles
Quote from: niles500 on July 10, 2016, 03:47:48 PM
It may simply be a local rule that nothing can be built in a flood zone.  I have not pursued the matter beyond city hall since I don't have the money saved to build yet anyhow.  The 40x50 I wanted to build was quoted at $55,000 by three different places.  I'm thinking about just doing half as wide and a little longer to save money, but it will still be $30,000.
Flex seal now comes in a can so you can paint it on. Also Pep Boys sell Herculiner which seems to work well. I used it to coat the whole inside of my house battery box with satisfying results.
Quote from: chessie4905 on July 10, 2016, 06:07:16 PMPep Boys sell Herculiner which seems to work well. I used it to coat the whole inside of my house battery box with satisfying results.
    That's a good thing to know, Chessie - thanks!
