How to remove sikaflex - Page 2
Started by Scott & Heather, September 03, 2015, 02:39:30 PM
This is good info. Part of the issue is that the factory foam blocks behind the belt line portion of the skins are bowed out. This gives the coach a "pregnant" look which isn't quite what we're going for. So I may just pull the panels, remove the foam and install flat foam, and then put new panels on.
Seangie
Scott -  Grab an embossing gun from Michael's for 20$.  Try that.  They get up to 650 degrees and its a good way to try it out before spending a whole lot of money and time.
'Cause you know we,
Driving through the night
To that old promised land'
Sean I might
Just use my heat gun on low
