OTR tire / wheel newbee questions
Started by Darkspeed, August 23, 2015, 07:12:17 AM
Todd -
Good to see that you're being conscientious about your wheels & tires.  Since we have to foot the bill. . .
Also glad to see that you're running 11R24.5s on your 4106 with the V-730 gearbox.  That taller tire compensates somewhat for the overall reduction in rear axle ratio with the automatic, compared to the OEM manual box.
Take a look at the samson 11R24.5 specs for revs per mile.  Ideally for the automatic, you should find a tire somewhere in the 470-475 revs/mile for closest to OEM performance.
I also agree that the deep lug drive tire is overkill on a bus.
Darkspeed
Thanks RJ, they come out to 463.6 revs per mile.
I went with lugs on the rear because im over adventurous and tend to wander out onto the grass at times.
It's all math and metal...
Darkspeed
Spoke to the manager and he was super nice, even asked if they were polished because they protect the polished face when working.
Mount: 12.50 each
Spin balance: 33.00 each
They are near the Truck Pro store in Tampa so I may have to do some window shopping while the mount and spin.
http://mcgeetire.com/5353-tires-auto-repair-service-tampa-fl
Darkspeed
Tires mounted and spin balanced. Super nice place to get it done! took 45 min.
Now all you need is the engine and transmission installed to take it for a drive. Good Luck, TomC
Darkspeed
Quote from: TomC on August 28, 2015, 06:43:15 AM
A little more than that but I sure am looking forward to it!
